Citroen C4 VTS ALARM ECU location?
Hoffies
Hi to all, I am new to the citroen world and unfortunately already need to ask a question, my car alarm goes off every time I unlock the car or open a door, even when car not locked. Every time the door is shut the alarm seems to arm itself after approx 45 secs. I Connected it to the lexia and shows No communication dialog with Alarm ECU. Any Ideas? I am thinking of replacing the Alarm ECU but I cannot find it. Can anyone help. Does the Alarm ECU need to be matched or reprogrammed?
Fake Concern
- x 65
Re: Citroen C4 VTS ALARM ECU location?
I hope you don't get exited thinking I might have an answer to this as I'm afraid i don't. the best i can suggest is try disconnecting the battery to see if it all re-sets. Also have you looked at the connections to the interior motion sensor switch? might be worth a try.
I really wanted to say hello to a fellow C4 VTS owner, we are starting to build up quite a gang of C4 Coupe owners on this forum now.
- x 1055
If i remember right the alarm ecu is on the bulkhead behind the glovebox. Some basic settings need to be made with lexia like the country the car is being used in & the type of interior. There is no problem re using an alarm ecu from another car.
Have you checked to see if there is water in the siren ?
Hoffies
Yes, the VTS is a flashy vehicle with some nice features! I removed the glovebox but only found the BSI with fuses and tonnes of wiring, I have no clue what the alarm ecu looks like! I had a look on the steering side, removed panels, but found only a stepper motor(I think) for the ventilation. Any help further will be great!
- x 1055
The alarm ecu is a small black box just slightly bigger than a 10 pack of fags, it has a 2 plugs on it, a blue one at the top & a smaller brown one at the bottom. I think its located either above the BSI or clipped onto the bulkhead behind the glovebox.
Citroening
- x 19
Hoffies
Hi again, well took out the glovebox, left side in my car, looked everywhere with flashlight and mirror, only the BSI on glovebox side, no other boxesbehind, above, nowhere, I found the engine ecu in the front fuse box, the airbag box under the handbrake/gearlever, have seen no other boxes at all. Behind steering wheel(right side in my car), nothing but stepper motor for the ventilation, I have no idee where else to look? Please help. Cannot find siren nor interior motion sensors, alarm activation LED or anything that suggests that I have an alarm, although I am sure all vehicles after 2005 were imported into South Africa had alarms, and the BSI is looking for one? Please help guys!
- x 1055
It's kind of sounding like your car might not have a factory fit alarm, maybe yours is an aftermarket fit ?
