espace and laguna compatability
russ hdi
Unread post by russ hdi »
hello,
i need to replace the clutch hydraulics on my mk 3 2.2dt espace so of i travelled to breakers yard where two espaces both off which where relieved of clutch hydraulics so common problem. however there is a 1.6sport laguna and i am interested if clutch hydraulics will swap over and if tinted sport headlights from laguna will fit conveniently the car is same colour as mine and apart from the headlights the grille appears the same also if any other parts are swappable and worth getting advice would be appreciated.
CITROEN C5 2.0 HDI SX 2003
Currently rebuilding grand espace 2.2 rxe full leather 3 sunroofs
