1.6 HDi limp mode
- x 1485
1.6 HDi limp mode
Lighty
- x 35
Re: 1.6 HDi limp mode
Handbrake always goes off with C4 Picasso's, when the engine light goes on.
Most common fault is a fuel pressure issue caused by dirty fuel filter. If you get any fuel related faults, I would go for this 1st
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
- x 1485
Thanks Lighty - It's not ticked in the service record at the 37.5k service, so it may not have been done ever (60k now)
How on earth do you get it out???
Mandrake
- x 695
Ah the joys of modern cars... 5 minutes with a screwdriver to change the fuel filter under the rear of my Xantia!
Well, 10 minutes to find something to remove the mounting screw whose head was completely rusted to nothing with 14 years of road salt, THEN 5 minutes to swap the filter...
60k miles Richard ? Perhaps you better find your previous forum post from last time I visited with the Lexia because I'm sure you'd only done about 40k miles then and based on the Lexia reading we took estimated the Eolys would run out around 60-70k ? Maybe its nearly due ? I guess we'll find out soon enough...
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
Lighty
- x 35
If that's not been changed it will for sure cause issues, we do them every 2nd service now, as the price has dropped quite a bit.RichardW wrote:Thanks Lighty - It's not ticked in the service record at the 37.5k service, so it may not have been done ever (60k now)How on earth do you get it out???
If you take the air box intake pipe off that goes over the top,of it, it is just possible to get it out.
Personally I would remove the air box lid (three Allen head screws 4mm ), then it's a piece of cake.
It pushes down into a slotted holder, part of the filter has to be removed and fitted to the new one, so don't chuck it away.
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
- x 1485
Cheers - I am going to get one on the way home, and if it decides not to be blizzarding this afternoon will stick it in.
Mandrake
- x 695
Good luck with that one.RichardW wrote:Cheers - I am going to get one on the way home, and if it decides not to be blizzarding this afternoon will stick it in.
Simon
1978 CX 2400
1978 CX 2400
- x 1485
Wasn't too bad here this PM, but no time for looking at cars. I got a filter - £28, that's a good wheeze "Yeah, let's not make the element replaceable, just a complete unit"! Mind you that's better than:
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT
0000190195 DIESEL FUEL FILTER SEAL 44.78 GBP 53.74 GBP
EML is still on, despite quite a few starts, but performance is OK, although not given it full welly, but went to Edinburgh and back this pm (80 miles round trip) without incident. Does the light eventually put itself out again?
Mandrake
- x 695
Ouch £28 for a fuel filter... I guess its tolerable but it does make you wonder how much we're getting ripped off for parts on more modern cars which seem to be getting ludicrously expensive and must surely be many times the manufacturing cost...
Regarding the light - I think it depends on the ECU in question... I always thought permanent faults would remain in memory until reset with a tool like a Lexia but I came across a passage in the technical documents for one of the ECU's in the Xantia, I think the Bosch MP7.0 for the V6 engine which said something along the lines of "a fault that does not re-occur in 40 starts of the engine will be automatically removed from memory", in other words a permanent fault such as a faulty oxygen sensor which is then replaced will clear itself after 40 stop/start cycles of the engine...
It's probably still a good idea to put it on the Lexia anyway in case there are other related or unrelated faults.
It's been snowing all night here, we went visiting tonight and in the time we were out over 30mm of snow fell on the car and the unsalted roads where we were visiting... it was the first time that I've actually needed to use the snow mode on the gearbox, which worked very well - although even in snow mode I needed to be gentle on the throttle to climb a steepish hill to get back out onto a main salted road..a bit too much welly and I could feel the driving wheels taking turns letting go, likewise a fairly gentle jab of the brakes even at 20mph was triggering the ABS, so not much traction...gentle throttle and brakes and it was perfectly fine though.
Simon
1978 CX 2400
1978 CX 2400
Lighty
- x 35
Those filters are also used on Fords, as they are so common, we pay less than half that for them, at least you got hold of it
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
- x 1485
New filter in - the designers of this arrangement were lambasted a few times during the process! We were out in it this afternoon, so took the opportunity to change it out when we got back, working over a nice warm engine makes it so much more appealing when it's freezing
Looks like the original filter going by the casting date on it. Been out for a run in it, and despite trying hard, I couldn't provoke limp mode, so hopeful that is the right route.
- x 1485
Mandrake plugged his lexia in today, and it had recorded faults on low fuel pressure, now cleared and the EML has gone out. It has run fine since the filter was replaced, so think that's cured it.
It has got a fault recorded for glow plugs - this was present last time we looked, and we cleared it then. It has started fine all winter, so I suspect it is down a glow plug - what are they like to change on this engine?
Mandrake
- x 695
PM me your email address Richard and I'll email you those PDF "printouts" of the logged faults and the Eolys status so you have a copy for reference.
Simon
1978 CX 2400
1978 CX 2400
Lighty
- x 35
Good diagnosis then
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
addo
- Sara Watson's Stalker
- x 95
