C5 MK1 leather install
KP
x 27
Unread post by KP »
I'm sure I have read on here of people doing this install into normal C5's.
I've got an exclusive and with leather interiors being so plentiful at the minute it seems worthwhile as would help my folks if they inherit it to slide my mum in and out.
Also can hatch and estate interiors be mixed like xantias could be or just a big no in c5's?!
Citroenmad
x 110
Re: C5 MK1 leather install
Unread post by Citroenmad »
As far as I know the leather interior plugs into the loom which is already there, though you had to add in a fuse to the fuse box.
Estates and hatches are different I think.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
KP
x 27
Unread post by KP »
Ahh fraggle rock sticks!
Will the covers for the rears peel off an transfer possibly then as I'm guessing the rear are difference.
x 1240
Unread post by Peter.N. »
I have just finished doing one today. The seats came from an Exclusive hatch, I first fitted them into a 2.2 estate but I have just sold that so they are now in my 2.0.Hdi estate, it seems that all the dooors are the same.
The plugs are under the carpet but you will need a maxi fuse fitted to the underneath of the engine compartment fuse box.
KP
x 27
Unread post by KP »
Peter that is great news!!
I think that ill be buying the leather ASAP then :
Muchly appreciated :)
waynedance
x 8
Unread post by waynedance »
For a car that has leather as standard, to add heated is it just a case of swapping the fronts for heated ones or is there still a fuse to add?
Volvo S80 D5.........
x 1240
I think by its rating, (80a ?) the fuse is for the heated seats, but mine don't work :(
KP
x 27
Unread post by KP »
That is one hot set of bottoms!
Must heat up ruddy quick is all I can say!
Citroenmad
x 110
Peter.N. wrote:I have just finished doing one today. The seats came from an Exclusive hatch, I first fitted them into a 2.2 estate
That is a surprise! In that case I could have had a set of leathers in my hatch as I found a nice set of estates. :shock:
03 Seat Arosa 1.0S
KP
x 27
Unread post by KP »
Where are the estate ones??
Citroenmad
x 110
KP wrote:Where are the estate ones??
That was a while back ..
03 Seat Arosa 1.0S
KP
x 27
Unread post by KP »
Dam.
KP
x 27
Unread post by KP »
Peter do I need to lift the engine fuse box out? And anyone got a diagram at all??
KP
x 27
Unread post by KP »
Found it! Only blank fuse in there so all done :)
To be safe I stuck a 50amp one in as I thought niether motors and heaters will be on all at once so should be safe :)
x 1240
Sorry, only just looked at my post - anyway you found it, well done.
