need new car, opinions about hdi xsara estate?
fotobright
Unread post by fotobright »
Xantia has gone to the scrappy's after years of service.
Someones offering my a 2004 hdi xsara estate with full year MOT for cheaper than other 2003/04 cars . I can only afford a £500-ish car and this might come in around that.
I dont know the xsara, it doesnt get a good write up but I said i'd view tomorrow morning. I thought it was worth a look as the running costs are pretty low but only if its not knackered. Electrics seem a bit suspect on these cars!
What should I be looking out for with an xsara HDI?
bests
Peugoet 308 SW HDI 1.6 Live*
Peugoet 207 SW Hdi 1.6
C5 2.2L HDi 16v estate (01)
Xsara Hdi 90 estate
Xantia 1.9TD estate, (veg oil)
Zx 1.9TD hatchback
Zx 1.9D hatchback
citroenxm
Fallen Hero
x 70
Re: need new car, opinions about hdi xsara estate?
Unread post by citroenxm »
HDi engine is common Xantia etc engine, and rather good....
Rear axle is a common issue.. The rear arms lean in like the old BX used to, and the top of the tyre inner rubs the inner arch..
Rear axles have a waiting list its that common, for replacments... repair can be a PITA to impossible..
Blowers are like the Xantia ones... simmilar setup.. it will work or stay on high speed.. Dash vents destroy them selfs.. outer door handles can break.. check front springs for fracture etc... other then that, not much else I DONT THINK...
A very sad...
1994 XM 2.1 d auto
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
The Xsara Estate isn't common in the UK but over in Spain, there are loads of them about. My daughter has the hatchback version of 2002 vintage and she loves it. For a short period some Xsaras had a sub-standard heater matrix fitted, but those were already leaking within 18 months from new. Also she's had the heater motor trouble where the fans blow at full speed. I changed the transistor pack but that didn't cure the problem so I took the easy way and fitted a replacement. At 100K the rear wheels were leaning inwards so much that with driver and a passenger, the tyres scraped the bodywork. I drove the car to Mountjoy Engineering at Honiton where they fitted a fully recon axle in about three hours. The car's done around 112000 miles and it's been very reliable. Belt and tensioners were done at 85K and the clutch is original.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
citroenxm
Fallen Hero
x 70
Much what I said there.. Phew a bit of back up there.. I'm usually wronged or come tell off the subject.. :-)
A very sad...
1994 XM 2.1 d auto
fotobright
very useful advice,
Would a car fail an MOT with the rear wheels were leaning inwards?
The car i was talking about was sold before i got to see it this morning. I just bought a fleabay xsara with 10 month MOT with no advisory's on the basis that things like the rear axle problem might be picked up at MOT stage. thus the question.
It sounds as if its a problem that might not be detectable until the car is under load, like when I hitch a trailer to it, which is exactly what I want to do. When I go to see the car/ collecting is there any way for me to measure the deformation or wheel height to indicate there might be a real problem, short of filling the car with a rugby team?
Xsara Hdi 90 estate
Zx 1.9TD hatchback
Zx 1.9D hatchback
JohnD
(Donor 2022)
x 72
fotobright wrote:Would a car fail an MOT with the rear wheels were leaning inwards?
Our Xsara's axle trouble first showed itself when the youngest girl told me about a sqeak. She said it wasn't always there, but usually heard it when she drove over a speed bump or had passengers in the car. After a lot of months, I had the rear wheels off changing the rear discs. Only when I got to the o/s wheel did I notice the mud and paint rubbed off the wheel arch. A look at the tyre confirmed the contact. Presumably, the bearing wear had been going on for a long time, however it wasn't picked up at the previous MOT's.
Even with new bearings in the axle, there is very little space between the top edge of the tyre and the wheel arch. Tyres can be from 175 to 195, so space is at its minimum with the broader tyres. Short of removing a wheel to examine the wheel arch, there isn't really a way of knowing.
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
fotobright
Just picked up the xsara estate and drove 150mls back. Its economic at 56mpg at a constant 70, so thats better than the old pre HDi Xantia.
Pretty punchy engine infact and all the electrics worked, horray! So the xsara seems like an ok buy at the mo.
The ride doesn't compare to the Xantia though does it. I know it cant compare but I found all the extra roll even a straight line slightly queazy. Used to own a Zx TD which I guess a slightly similar feel. I will check the tyre pressure. I didnt hear any obvious scraping from the back wheel arches and it didn't appear to be sitting low at the back either but at 145,000.
Is there any way I can improve its ride? It felt like it needed to adjust itself faster to the road, too lolliping....
Early days, only just got it this afternoon.
Xsara Hdi 90 estate
Zx 1.9TD hatchback
Zx 1.9D hatchback
citroenxm
Fallen Hero
x 70
Yes.. Change it for a xantia estate.. :-D :) :) :)
A very sad...
1994 XM 2.1 d auto
waynedance
x 8
Unread post by waynedance »
Change it for a proper Citroen................
Volvo S80 D5.........
addo
Sara Watson's Stalker
x 95
Unread post by addo »
The rear axle repair bits are about £45 per side (pin and bearing kit); you would be mad not to do both at once. It does require some workshop tooling as the rear beam must be removed and new pins fitted with a press.
