c5 locking wheel nut tool
bill196510
Unread post by bill196510 »
Has anyone local to alfreton got a removal tool I can use for 5 mins, lol.lost mine 2 days ago,
need to get rid of those bloody Things,
only done one side, pads, track, drop link
C5 2.2 hdi 2003, called it oliver reed, drinks like him :(
Good on fuel now, lol.
x 1052
Re: c5 locking wheel nut tool
Unread post by wheeler »
Do you mean a specific removal tool for removing them when the keys are lost or the actual key that comes with the car ? if you mean the key that comes with the car then they are not all the same, there are about 30 different combinations for each type of bolt.
bill196510
Any that will do job
bill196510
They have been off recently, so not stuck on
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
If you've lost your key (which is unique to the car) and going to replace with a regular wheel nut, go to a tyre depot. They have the tool for removing a locking nut.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
bill196510
JohnD wrote:If you've lost your key (which is unique to the car) and going to replace with a regular wheel nut, go to a tyre depot. They have the tool for removing a locking nut.
Rang depot, they wanting 40 to remove all4, draper expert tool is 20, so getting that lol.
Lighty
x 34
Unread post by Lighty »
Good luck, these are hard to remove, let me know if you get stuck, only in Ilkeston.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
bill196510
Lighty wrote:Good luck, these are hard to remove, let me know if you get stuck, only in Ilkeston.
cheers,cant believe i lost it,used it day before,lol.
bill196510
removal tool didn't fit,ended up ordering replacement key for citroen £50.58 ;-(
G4EIY
Unread post by G4EIY »
It has been possible to remove the wheel bolt using a suitable sized socket, hammered on the the bolt head.
Another method, weld a nut onto the head of the bolt.
Good luck
Brian - 86 Visa 17D Sorn(192K)/ 86 BX 17RD (220K) Scrapped/ 92 BX 17TZD Turbo Diesel (191K)
96 306 XRDT (174K)
dnsey
x 19
Unread post by dnsey »
Trouble is, the Citroen bolts have raised heads designed to break away under torque, as they only act as a guide for the key. The actual driving surface is a flat flange with uniquely spaced holes for the key.
bill196510
can somone tell me if this is genuine citroen locking wheel nut
saw set like this on wbay,saying genuine c5 in citroen bag,with logo
" onclick="window.open(this.href);return false;
JohnD
(Donor 2022)
x 72
Well it looks nothing like mine. I'll try and get a picture .
Here you go:-
Image[/URL]
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
x 5672
Mine was very similar to that - until I got rid of the locking wheel nuts. Nothing but a nuisance.
