Saxo Strut tops
jmd
Saxo Strut tops
Has anybody carried out this job, or can the tops & bearings be replaced (on the car) without removing the whole suspension unit
Chris570
- x 36
Re: Saxo Strut tops
It's easy, and i suppose you could in theory leave the strut on the car but it's sooo easy to just remove the leg.
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
- x 94
Re: Saxo Strut tops
the only way to do this is with the strut off the car as it will make compressing the coil spring far easier
Regards, malcolm.
spider
- x 77
Re: Saxo Strut tops
And safer too, would not want fingers in the way between inner wing top and strut even if compressed...
They are quite 'long' springs when uncompressed although you'd not really need to uncompress them to see that. Remember its the "whole" strut assembly as it does not separate from the hub on these.
The only extra you may want is a bottom balljoint pinchbolt / nut as I find these sometimes like to snap when being undone, probably previously over-torqued or possibly just age. I used to keep a couple in my toolbox (and there's at least one if not two there now)
Quite straightforward to do, although I still have an occasional knock from mine (decided its rack related but that's something else, not much else left to change)
Andy.
- x 94
Re: Saxo Strut tops
and to add the Andy's handy things to have is new hub nuts as these are peened over to lock them on
Regards, malcolm.
spider
- x 77
Re: Saxo Strut tops
Mine were re-used by the previous ownercitronut wrote:and to add the Andy's handy things to have is new hub nuts as these are peened over to lock them on
I have obtained some new ones out of worry but not fitted them yet, I hammered the peening down a bit more but that may of weakened it actually.
I see there are two types as well changing a build code, at least its easy to tell as the later ones are a lot "longer" , earlier ones look like 205 ones.
Andy.
- x 94
Re: Saxo Strut tops
it it usually possible to re/use them once by swaping one side for the other ( not always though )
you can also if you are really stuck file the matting surface of the nut down so the peening zone is at a fresh point, as the nut will wind on a bit more dependent on how much you file
Regards, malcolm.
