Handbreak cable snap Xantia HDi
Sid_the_Squid
Unread post by Sid_the_Squid »
Hi everyone,
Can someone give me advice on how easy/hard it is to change a handbreak cable on a '99 HDi xantia, last night mine snapped :(
Check the BOL it talks about drilling out rivets on a heat shield and popping off gear selector rods, removing the mid section exhaust, sounds like a real PITA and beyond something I'd try at home, as I've a MK2 xantia the gear selector rods are replaced by cables (i beleive), but is the heat shield still present? do I need to drill out rivets? how hard/easy is the cable routing, and why remove the exhaust?
I did a forum search didnt find anything, could be my bad searching skills.
any advice appreicated.
Gone to the dark side.
Past Citroens
'99 Xantia HDi Exclusive
'99 Xantia 3.0 V6 Exclusive (Green Goblin)
'02 C5 Hdi 110 LX Estate
'98 Xantia 1.8 sx auto with LPG
'00 Xantia Hdi (110) forte
'97 Xantia 1.9D sx
'93 Xantia 1.9D lx (my first) R.I.P
x 94
Re: Handbreak cable snap Xantia HDi
Unread post by citronut »
hi Sid nice top see you back in these parts again,
no need to drill any rivets, just ease the heat shield away at the front N/S corner, enough so you can get a finger into the hole in the side of the cable compensator box to flick the hook end of the cable off of the compensator,
quite a simple job once you have been there
Regards, malcolm.
Sid_the_Squid
Thanks Malcolm,
nice to be back :)
So no need to remove the heat shield, or the exhaust then, thats good.. any other tips, is cable routing fairly obvious or anything which is likely to catch me out?
Might try tackle this saturday if the weather is good
Past Citroens
'97 Xantia 1.9D sx
x 3297
Quick question. Which cable has failed? I have replaced both secondary cables on Gracie, and it wasn't a difficult task. I have no experience of the primary cable.
Sid_the_Squid
Good question,
I really don't have a clue, is there an easy way to tell?
I can't get under the car today, it will be dark by the time I'm done with work.
Symptons are handbreak totally inffectual, pulls all the way to the top with no resistance, no attempt to make the breaks come on.
Past Citroens
'97 Xantia 1.9D sx
x 8423
Sid, if yours is a 110 be aware that the handbrake cable on one side (Nearside I think) is longer than on other models (except the Activa, 2.1 and V6 - the big engine models) and is not generally available from the likes of GSF who only do cables suitable for the small engined models so do make sure what you are offered is the right ones.
Simon (Mandrake) has been here and can advice...
As said, the actual job of replacing them is a doddle :-D
x 3297
Hello Sid,
There are three cables involved. The primary goes from the handbrake lever to the compensator/balancer, where the two secondary cables then go off to each of the front wheels. The normal place for a secondary cable to fail is near to its' wheel, where the cable passes through a guide loop (each cable passes through several loops on its' route, but it is the one mentioned that usually has the problem). The sleeving wears at this point, and (over time) it wears through enough to allow moisture (and dirt) in, which means the cable itself gets rusty. This can cause binding, and (eventually) the cable will fail. When either cable fails, the compensator cannot cope, and has the symptoms you describe.
I have not had to replace a primary cable, so I do not have any experience of this. I would guess (guess, mind you) that if this failed it would have the same feel.
The way I would check is to get the car up on ramps (or stands), chocked to stop it moving, get underneath with a 10mm socket, short extension bar and ratchet, and (near to the exhaust, about a foot back from the subframe) there is a heatshield. Remove this shield (two nuts), and you can see the compensator/balancer. Now pull on the handbrake, and have another look. If the compensator hasn't moved, it's the primary cable that has failed. However, if it has, but un-evenly, then a secondary cable has failed. IIRC the upper cable goes to the right wheel, while (obviously) the lower cable goes to the left wheel (but I am not sure of this, doubtless a more knowledgeable person will confirm or correct me on this). Assuming I am right, if the top of the compensator is canted forwards then it is the bottom cable that failed, and vice versa
When I replaced these cables recently on Gracie they cost me about £50 for the pair. It only took a couple of hours, and the most fiddly bit is threading the nipple onto the compensator.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
SPOT ON JAMES......! :-D :-D :-D
A very sad...
1994 XM 2.1 d auto
Mandrake
x 695
Unread post by Mandrake »
Sid_the_Squid wrote:Hi everyone,
I don't know about the HD110, and it's probably different as the catalytic converter is different, but on my V6 the catalytic converter is so large I was unable to get sufficient access to the handbrake balancer box without removing the heat-shield, which is a bit of a PITA to be blunt, as you have to bend the shape of it to thread it out over the top of the exhaust, and one of the nuts that holds the balancer box is nearly impossible to get at. (Ratchet spanner highly recommended...)
I know some people say you can get a finger in the balance box through a hole in the side to unhook the old cable and hook the new one one, but I couldn't do it. Maybe you can on other models of Xantia. If you can do it without removing the heat shield thats all good, but be prepared to remove the heat shield as plan B...
Sid_the_Squid wrote:Good question,
Almost without doubt one of the cables will be broken near where it passes through the guide loop attached to the wheel hub, like this:
Here is what was left that was initially still threaded into the hub:
CitroJim wrote:Sid, if yours is a 110 be aware that the handbrake cable on one side (Nearside I think) is longer than on other models (except the Activa, 2.1 and V6 - the big engine models) and is not generally available from the likes of GSF who only do cables suitable for the small engined models so do make sure what you are offered is the right ones.
Indeed Jim, getting the correct cables for a V6 (and HDI110 if its the same cables) was a real saga. :roll:
Sid, rather than duplicating what I've said elsewhere, have a read of the last post in the following thread:
http://www.frenchcarforum.co.uk/forum/v ... 3&p=328811" onclick="window.open(this.href);return false;
The summary is that GSF are able to supply the cable for the right hand side (but their part numbers are wrong on their website, confusing left and right cables!) while the left hand one which is unique to the V6/HDI110/Activa is only available from Citroen themselves. (Citroen no longer stock the right hand one) Full details and photos in that thread.
Sid_the_Squid wrote: any other tips, is cable routing fairly obvious or anything which is likely to catch me out?
It might be obvious, but take note of which way the two handbrake cables cross each other below the engine - its not obvious, and if they cross on the wrong side of each other (one goes above one below) they won't move smoothly as the steering turns which could lead to them snagging and pulling the handbrake on when turning on full lock. Check that both cables can slide sideways freely a few inches at the point where they curve around and cross each other.
If you're removing both cables at once take note of which one comes out of which side of the balancer box as this again affects the cable routing - there's more than one way to route the cables and cross them over each other and not all of them are optimal...I didn't take careful note and it took me quite a bit of trial and error to figure out the optimal routing to allow the cables to move freely.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 1496
Euro car parts / carparts4less do the correct NS cable for the HDi 110 - at least the one I got from them did the job OK. On the 110 HDi you need to remove the heat shield, but it's small, and easily removed by undoing one 10mm nut at the back, and then popping off the clip at the front. I have fitted 2 sets to mine, and both of the OS cables have been a bit short - they only work with the adjuster backed right off, but seem to be OK adjusted like that. Both cables doable in less than an hour - it's surprisingly easy :lol: Never heard of anyone having to replace a primary cable.
Mandrake
x 695
I didn't try carparts4less Richard, do they look the same as the ones in the picture below ?
Sounds like they're supplying the same length cable for both sides if the right hand one is a bit short - there's a difference of about 20mm between the V6/HDI110 left cable and a right cable. In the above picture the top cable is the left hand cable for a small engined Xantia, the middle one is the left hand cable for the V6/HDI110 (big difference between the two) and the bottom one is the right cable for all Xantia's.
So if you had the middle length cable on both sides it would pull a bit tight on the right. At a pinch you might be able to get away with using the bottom long cable on both sides if that was all that was available, it would just make a slightly bigger loop where they cross.
The right cable I got from GSF and left cable from Citroen (bottom and middle cable in the picture respectively) are both a perfect length and fit for the V6.
Simon
1978 CX 2400
x 1496
The cables are different Simon - the RH cable has a heat protector on it. The previous one was from a different supplier, same 'fault' but works OK.
x 94
here are all the secondary cables listed on service citroen for MK1's
4745 G5
SECONDARY BRAKE CABLE
LEFT
LONG 1265
- EXCEPT BVM ML5T
4745 H5
LEFT
LONG 1295
- BVM ML5T
4745 G5
LEFT
LONG 1265
4745 G6
RIGHT
LONG 1335
and MK2
9
4745 G5
LEFT
LONG 1265
- BE3 UNTIL RPO 07972
LEFT
LONG 1265
- BE3R MANUAL GEARBOX SINCE RPO 07973
4745 H5
LEFT
LONG 1295
- BVM ML5T
LEFT
LONG 1295
- HP20 (AG)
4745 N3
LEFT
LONG 1285
- Auto gearbox AL4
10
4745 G6
RIGHT
LONG 1335
- EXCEPT INJECTION ES9J4
4745 J4
RIGHT
LONG 1365
- INJECTION ES9J4 AND LEFT HAND DRIVE
4745 J5
NFP
RIGHT
LONG 1335
- INJECTION ES9J4 AND RIGHT HAND DRIVE
Regards, malcolm.
Sid_the_Squid
Hi all,
Thank you all so much for all the advice, its really excellent :)
I've done a simple test, car on high, full lock left, then full lock right, seeing which, if any, cable would become tight with the handbreak on.
Turns out the NS (passenger side) cable has snapped at the wheel, just as shown in the picture mandrake posted, the OS cable seems to still be in good condition.
So from what I understand as I've the 110 hdi I need the longer, less common NS cable which I can obtain from Euro car parts / carparts4less, or from Citroen (at no doubt twice the price). I'll get on the phone to euro car parts as there is a depo 2 miles from my house :)
Thankfully my car is de-catted, so hopefully enough space to get the heat shield off and put the new cable in... just got to find
a) a flat surface,
b) wait for the glorious british weather to swing back to sunshine, or at least stop raining ;)
Thanks for all the help and advice everyone :D
Past Citroens
'97 Xantia 1.9D sx
Sid_the_Squid
Result! euro car parts say they will have a long NS cable for my car in the local depot by 14:00 :D now hoping for good weather Sunday.
Past Citroens
'97 Xantia 1.9D sx
