Well, as we're talking gearbox noises. (Synergie 1.9td)
Johnny Cogs
Unread post by Johnny Cogs »
When I lift off the old Loud pedal theres a bearing-esque noise from the gearbox. It's also present when reversing.
Doesnt sound like a typical thrust bearing, as (in my mind) it sounds a bit more affected by the gearbox casing (as in the noise a casing makes when you tap it.... with a hammer! :p )
I hope that makes sense?
Does that sound familier to anyone at all?
'rolls in a 1.9TD Syn-bus!'
x 1240
Re: Well, as we're talking gearbox noises. (Synergie 1.9td)
Unread post by Peter.N. »
Have you checked the oil?
Johnny Cogs
Ummmmm yes, honest..... maybe..... well...... erm....... no, actually.....
(runs to Helfrauds and hopes this thread magically dissapears!!!)
x 3306
It hasn't yet!
It could be worth changing the oil in the gearbox as well. I am not sure of the interval on your 'box for an oil change, it could be worth checking the Haynes BoL (or, better yet, getting an expert to tell you). The oil you need is likely to be 75W80 oil, which you can get from Citroen. 2 litres cost me about £15
Harlequin
x 24
Unread post by Harlequin »
i got 5 litres of comma g/b oil for £20
http://www.ebay.co.uk/itm/COMMA-EP75W-8 ... 3ccde98ff8" onclick="window.open(this.href);return false;
did my old petrol 806 and will be going in the TD syn
Simon
Johnny Cogs
Hey Chaps, apologies for not returning to the thread... been uber busy.... have all easter weekend and following week off work so will get the change done in the next few days. Thanks for the advice Razor, and for the link Harlequin, I shall be purchasing that very bottle in a few clicks time :) I'll keep you posted!
Johnny Cogs
Nipped out on my lunch break and got 5ls of the above for almost the same price, but I have since noticed quite a few folks saying they have used semi-synth whereas this is a full mineral oil, should I be concerned?
Johnny Cogs
Hey Folks! Happy Easter!!!
So I finally got the oppertunity to go look at the Syn-Bus and fill it up with lovely new gearox oil....
erm, unfortunately I cant see the drain plug OR a filler plug anywhere!!!
do i need to do something rediculous like tear out the airbox, wishbone and subframe to find them???
any pointers much appreciated....+
oh, and if it helps me win a sympathy vote I doscovered a cat had peed on the front bumper....... AFTER I had dragged my fat frame under the wagon... :-(
Johnny Cogs
This page here
would suggest both the drain plug and filler are on the diff?
Great.... Nice Easy Access :/
Johnny Cogs
well, afetr a LOT of faffing about and bodging stuff I have got the gearbox oil changed....
Still bloody noisy..... :(
Harlequin
x 24
what was the old oil like when it came out?
Simon
Johnny Cogs
pretty black, under 1.5l came out. the oil was quitethin, ran quite easily and left a film of umber coloured clear oil....
Harlequin
x 24
ran like water? mine was gloopy like oil but when a friend did his , it came out like water.
did you refill with the car level ?
Simon
Johnny Cogs
yeah like water. I wiped a graphite like substance from both the plugs.... at first I thought the previous owner might have put graphite grease in there to hide the rattle.... :p
No I refilled (overfilled) with it jacked up at the front, so I could keep an eye on my redneck filler assembly, which was hastily removed and replaced with the filler plug, then dropped to the floor and checked.... had to make a little puddle in the street....that is not admissable as a confession in a court of law!!! lol
Johnny Cogs
Hey Folks. Managed to grab some internettings time today. Thought I would add a little update to this thread (plus its MOT time so I am scouring the site for solutions :p )
After the oil change I was quite disheartened as it was still rattling.... So I used the Vectrarse for work for a couple of weeks and Mrs JC used the Syn bus for the school runs as is the norm....
I needed to use the bus to go and collect some wood supplies... Well if I didnt jump in that thing, drive off and (after about 5 mins) think to myself 'wheres the rattle gone??' Obviously it just took a long time to truly work its was around the ol' box of gears and swarf =)
Moral of the story? Patience, young grasshoppah!
