Sphere life
davewithington
Sphere life
Unread post by davewithington »
I've just bought some new spheres from a well known and trusted supplier
They have a manufacture date of 2003. Do spheres deteriorate in storage?
Citroenmad
x 110
Re: Sphere life
Unread post by Citroenmad »
I have found that spheres keep pressure if in storage. We have a number of Gen Citroen spheres which are not all that new and if I use some I pressure test them, they have always been spot on. Well, usually ever so slightly over.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
davewithington
Re: Sphere life
Fair enough Chris.I'll pop them on tonight
The spheres on the Green Goddess were changed in 2007, so as a precaution I'm changing the lot, yes all 8, so I know where I'm starting from
There has been a lot of money spent on this car, but not recently. No, no I don't mean it's rubbish!
Mandrake
x 694
Re: Sphere life
Unread post by Mandrake »
Hmm. It depends what sort of spheres they are...
If they're grey C5 spheres, or long life multilayer Xantia spheres (three dimples around the filler cap at the top) and they're 10 years old but unused, chances are they're perfectly fine, even in use the long life Xantia spheres easily last 10 years without significant pressure loss.
However if they're standard Xantia spheres then even if they're unused it will be a lottery at 10 years! If the metal button at the bottom of the diaphragm has sealed well against the neck of the sphere there will be little pressure loss, however if it has not there could be a large loss of pressure.
If it were me I would be pressure testing them before going to the trouble of fitting them.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
davewithington
Re: Sphere life
Fitted them last night and there is a definite improvement, especially at the front which has lost its harshness. These were the 2003 spheres.
The ride wasn't bad before, just not supple
Citroenmad
x 110
Re: Sphere life
Going on experience I imagine they will be not far off the correct pressure if they have had a shelf life.
Good result :)
03 Seat Arosa 1.0S
