While driving on A406 today I had to stop from 40mph to a standstill. When the car was coming to a complete stop there was a long hissing sound from the rear. It's never happened before but reappers on complete stops from speed.
I believe it's coming from the rear brakes but not sure - does anybody have any idea? I haven't had any worn brake lights on the dash.
Many thanks.
Xantia hissing sound from rear brakes
Its quite normal to hear a momentary hiss from the brake (dozeur) valve on releasing the pedal after hard use, but this shouldn't last more than about a 1/4 of a second.
Its caused by the returning high pressure oil being forced through the restrictions of the valve
Longer than this could possibly mean trapped air in the brake pipes going to the calipers, try bleeding the brakes.
Dave
Dave
Presumably Nikolaymk has a hatchback, its rear pads are much smaller compared to the estate pads, also the front discs and pads on a 2.1 estate are much larger than those on the smaller engined hatch's and so much more powerfull which goes to aleviate the pain an the rears somewhat.
So not that surprising your rears are still healthy looking John, especialy if they are the originals, hard as rock, probably the discs that are suffering.
Anyroad up, I don't describe the metal to metal noise from brakes as a hiss, scrape yes.
Dave
Dave
