glow plug
paul whalley
glow plug
Unread post by paul whalley »
hi its been a while sold the old boxer had a saab now back in a boxer but she has a problem
i was driving back from work on Friday and i seen the glowplug light didn't go out and then started flickering. it hasn't changed the way it starts runs or stops.
got my brother to test if there was power to the glowplugs while the engine was running and there was don't no how many volts he did say but i cant remember #-o .
any one have any ideas
thanks
paul
Paul
Peugeot Boxer 2.0 HDI 53
Citroen Berlingo 1.9d 1998
Saab 93 1.9 (150) tid 57
peugeot boxer 2.0 HDI 54
paul whalley
Re: glow plug
forgot to say its the 2.0 hdi 54 reg
Paul
x 5674
Re: glow plug
Check the glow plug relay connectors. Remove the plug and look for corrosion. Spray with electrical contact cleaner and push it home/remove it a few times to get the contacts clean.
If that doesn't work it may be the relay itself sticking, fairly expensive to replace IIRC.
paul whalley
Re: glow plug
thanks where would i find the glow plug relay ?
Paul
x 5674
Re: glow plug
Couldn't say on a 406. It is right behind the battery on a 306. Never looked on my C5s and it isn't here yet so can't look at the moment.
x 94
Re: glow plug
Unread post by citronut »
Steve i thought Paul says its a Boxer :roll: :-D :wink:
i think the glow plug relays on vehicle's of this age are electronic, i have seen a 306 which burned the glow plugs out completely were the relay stayed on all the time, this was an electronic relay,
maybe being a HDI it will start without the glow plugs????? even in out ice age conditions
Regards, malcolm.
spider
x 77
Re: glow plug
Unread post by spider »
I'm not sure where it is on a Boxer, been a long time. Probably around the battery area.
Just follow the heavy wiring from the glowplugs and the relay will not be far away.
Andy.
paul whalley
Re: glow plug
thanks been to work today and the light came on as normal upon start up and went out as you would expect so now there seems to be no problem
would the wet weather we had when it started be any thing to do with it? a bit of damp got in some where?
Paul
x 94
Re: glow plug
being a 54 plate it could be an electronical gremlin/glitch/hiccup,
Regards, malcolm.
paul whalley
Re: glow plug
well all has been good for a few days and today it lashed it down so the glow plug light starts again it must be the damp getting in somewhere i think but where?
Paul
