Diesel misfire update
trx
Unread post by trx »
Done every check took all the advice off here (many thanks people) and today decided just to take the plastic covers off to check the little magnets on the flywheel to see why rev-counter was not working.
The little magnets where there oh yes but not as they should be just about half of them #-o
When the new clutch was fitted i gave him a replacement flywheel because the clutch had smashed to bits arm and all, he said "used your old flywheel as it was OK" =D>
Looks like it will all have to come off again to replace the magnets unless there is a way to replace them while its all still in there.
Thanks again all.
Dave
trx
Re: Diesel misfire update
Well got the flywheel changed and now i have a Rev-counter that works =D> but,and theres always a but its still smoking and the mifire is still there :roll: so will go through the list again and double check it all again then :wtf:
Dave
