I swear this car throws up a new niggle everyday! So far the list consists of:
*Cd player appears has a Cd stuck in it and will not play or eject
* rear brakes are squeaking quite a lot under braking, I suspect the pads, will investigate.
* cracks in the plastic cover of the instrument cluster, don't know if it can be replaced or not
* when the car is started the service light comes up and a warning message comes up saying 'airbag/seat belt pretensioner failure' but then clears after a minute with no trace.
* heater only blows lukewarm air even when on maximum, will blow cold fine and the dual zone climate works fine.
* carpets coming away by the passenger side front door and I cannot seem to keep it in place.
* gear change is quite sloppy and vague, don't know if linkages are most likely at fault.
Long list, any help coming up with answers or clues would be really appreciated, as my stress levels are rapidly rising, Cheers all!
To do list on the C5, advise if you can?
ankou
Citroen C5 2.0 VTR 2007 ........ My daily smoker
Citroen Saxo 1.6 VTS 2002....... under the stewardship of my missus :/
