Airbag/Pretension warning?
ankou
Unread post by ankou »
Good Evening All,
Just a quick one, when I got in the C5 and turned it on today, it flashed up the Airbag/Seatbelt Pretentioner Faulty warning with the service light on, after a few mins of driving they both went off. Now everytime I turn the car on the same happens, any clues?
Thanks in advance :)
Citroen C5 2.0 VTR 2007 ........ My daily smoker
Citroen Saxo 1.6 VTS 2002....... under the stewardship of my missus :/
x 1996
Re: Airbag/Pretension warning?
Unread post by Stickyfinger »
BUMP...me too !
Undone connectors and cleaned them, still the same...............BEEPs are driving me MAD....dribble dribble
x 1055
Unread post by wheeler »
See here > http://www.frenchcarforum.co.uk/forum/v ... s+footwell" onclick="window.open(this.href);return false;
x 1996
wheeler wrote:See here > http://www.frenchcarforum.co.uk/forum/v ... s+footwell" onclick="window.open(this.href);return false;
Thanks, will check in foot well
EDIT..
Opened, cleaned and remade a couple of times, still have fault :(
?? The only connectors are under seats ?? under a little flap .........YES ??
Edit
Just noticed these words
..........under the polystyrene false floor on the passengers side,.........carpet out again tomorrow
x 1055
There are no pretensioner connections under the seats on the mk1 C5 as the pretensioners are in the inertia reels not the stalks.
Yes you need to remove the polystyrene cover to see the connectors.
x 1996
double post
x 1996
Hi Guys
The car is a 2oo5 1.6d VTR Estate BTW
Well I took out the carpet and looked the under the polystyrene false floor on the passengers side...ZERO connections, there is a a loom in a flat protection box but no connectors inside.
Is it a good thing to take out the seats and put new connectors on / will a Lexa session show the connection that is faulty ?
AND.....where the heck will my connectors be :)
Any help gets a smile :)
x 1055
Stickyfinger wrote:will a Lexa session show the connection that is faulty ?
No, it will only show the circuit that is at fault, you then have to find out where it's at fault.
I'm not 100% sure if the mk2 C5 has the same connectors in the same place as the mk2 has quite a different electrical system, I somehow just assumed yours was a mk1. I've also just assumed this is a RHD car ?? The LHD versions won't have them either.
x 1996
NP....and it is a RHD...:)
Well, the next question.....Auto Electrician or Garage for this type of fault ?
x 1055
I'd say someone with a Lexia to at least give you a starting point of where to start looking.
x 1996
wheeler wrote:I'd say someone with a Lexia to at least give you a starting point of where to start looking.
OK....I will go to Phil Hunt in Tober, Dorset, I think he has one....I feel $$$$ needed :(
