The water house that comes of the right side of engine to the expansion bottle.
A 10mm rubber pipe comes of the thermostat (thinks) housing and after 10cm goes into a smaller plastic 5mm pipe for approx 40cm and then back into 10mm rubber hose to the expansion bottle.
Can I just replace with a 10mm straight hose from side of engine to the expansion bottle or is there a smaller pipe in the middle for a reason?
Thank you.
Quick answer needed on 2.2hdi C5 water pipe
waynedance
- x 8
Volvo S80 D5.........
qprdude
- x 14
Re: Quick answer needed on 2.2hdi C5 water pipe
Normally, a smaller bore pipe would be to restrict flow, or contain higher pressure. Must be a reason because surely it would be more cost effective to have a single size pipe. Has it been replaced maybe?
Rick.
2013 Citroen DS 5 D/Sport
waynedance
- x 8
Fitted straight 10mm pipe for now driven 20 miles and all good temp gauge in same place.
Will get correct pipe ordered to be safe.
