What engine number do I have?
beko1987
x 16
Unread post by beko1987 »
Thinking of teaching myself how to do a cambelt change, with my ZX as a test mule. What engine code would I have? 1.4 8v. Is it written anywhere on the engine so I can go and have a look?
Cheers
1997 Citroen ZX
1997 Citroen XM
1994 Citroen ZX
1997 Citroen Xantia
2005 Renault Laguna
2001 Renault Laguna
2002 Peugeot 406
1997 Citroen ZX
2002 Citroen Xsara
waynedance
x 8
Re: What engine number do I have?
Unread post by waynedance »
If i had your reg I can get engine number (work at garage)
Volvo S80 D5.........
beko1987
x 16
R385 VRD my man!
Can you get any other info about it? (Don't want to take the p**s so feel free to tell me to sod off!)
Cheers
1997 Citroen ZX
1997 Citroen XM
1994 Citroen ZX
1997 Citroen Xantia
2005 Renault Laguna
2001 Renault Laguna
2002 Peugeot 406
1997 Citroen ZX
2002 Citroen Xsara
waynedance
x 8
Copy and pasted, hope it makes sense.
Make
Citroen
Model
ZX
Sub model
{All}
Engine size
1.4
Year
1997
VRM Info
CITROEN
ZX SX
PETROL
1360
TU3JP(L90) (ENGINE CODE)
BHP~kW 75~55.9
Valves 8
Transmission
Manual 5 speed
Engine no
FS7A2049187
Emissions
0,E2
VIN
Year of manufacture
1997
Door plan
HATCHBACK (5 DOORS)
Date first registered
28/08/1997
Colour
BLUE
beko1987
x 16
Excellent - thanks!
Can buy the correct cambelt and waterpump kit in a few months now :-D
1997 Citroen ZX
1997 Citroen XM
1994 Citroen ZX
1997 Citroen Xantia
2005 Renault Laguna
2001 Renault Laguna
2002 Peugeot 406
1997 Citroen ZX
2002 Citroen Xsara
waynedance
x 8
No problem, Autodata says 1.6hrs for cambelt and does mention the use of a tension gauge.
beko1987
x 16
Thanks to your info I've found the correct timing belt and waterpump kit - http://www.ebay.co.uk/itm/CITROEN-ZX-1- ... 2c6a17d94b.
However I can't find anything about a tension gauge, is this critical or can it be substituted for a bolt/bit of wood/sweary words (delete as appropriate)
I'll buy the kit next month so I have it and it can inspire me to do it. Need to send my girlfriends off for it;'s change though, there's no room to move under her bonnet, and the £300 quote I;ve had seems reasonable enough!
1997 Citroen ZX
1997 Citroen XM
1994 Citroen ZX
1997 Citroen Xantia
2005 Renault Laguna
2001 Renault Laguna
2002 Peugeot 406
1997 Citroen ZX
2002 Citroen Xsara
waynedance
x 8
Work at a garage but I am Mr Admin not Mr Mechanic, sorry can not help with tensioner gauge.
x 94
Unread post by citronut »
you dont need a tensioner gauge on a TU engine as long as you can only just turn/twist the longest straight length of belt ( the run between the cam and crank sprockets ) a quarter on a turn, that should be about right,
in twisting it it need to feel quite tight though
Regards, malcolm.
x 8422
Here's a nice pictorial guide... It's for a 206 with the same engine but it'll basically be the same...
It really is quite easy. I show the use of a SEEM gauge there but as Malcolm says, it's not necessary...
beko1987
x 16
Wow that's a brilliant guide! Bookmarked for future use!
1997 Citroen ZX
1997 Citroen XM
1994 Citroen ZX
1997 Citroen Xantia
2005 Renault Laguna
2001 Renault Laguna
2002 Peugeot 406
1997 Citroen ZX
2002 Citroen Xsara
