Hello,
Update to my sat / Nav problems. i.e. Sat / Nav works fine but, will not save any Destination for future use. It says Destinations have been saved however, after an Ignition switch off and on, my added destinations have been forgotten.
I have purchased and fitted a secondhand Sat / Nav ECU, via ebay. However, it appeared to be DOA. Therefore, I have refitted my original unit.
I have been told that my Sat / Nav ECU is probably not getting its Constant 12v connection. However, I cannot find any Pinout.
Does anyone out there have the Pinout for my Sat / Nav ECU?
Its Part Number Is : 22SY541/35
If I can get this info', I will be able to test if my Unit is being supplied with a Constant 12v supply. If it is, then my Unit is faulty.
However, if, as I suspect, my Sat / Nav ECU is not being supplied with a constant 12v supply, then I can just provide it with a new lead.
Any help, much appreciated.
Paul
