Very likely a slipping AUX belt which will only squeal when the hydraulic pump puts a load on it...(it needs 5 HP to drive the pump under full load)
Check the belt condition and tension.
What's this noise likely to be?
Mandrake
- x 695
Re: What's this noise likely to be?
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
Old-Guy
- x 24
Yup. Auxiliary drive belt slipping. A slipping belt wears faster and faster. It snowballs: worn = slacker = wears faster.....
It needs replacing: if you tighten the worn belt until it doesn't slip, you risk over-tightening and then its the alternator or HP pump bearings that go.
Xantidote
- x 4
Early TDs (such as my 1995 S1) had manual tensioner, whereas later TDs had auto-adjusting set-up. There's another thread at the moment on the auxillary belt topic.
Before you remove the belt, make a mental note/sketch, or even get the digital camera out, to ensure it all goes back the same way. I once tried a new route for the belt and not surprisingly, I couldn't make it fit
Martin
1995 Xantia TDLX (deceased
Old-Guy
- x 24
That's Citroen's price. GSF are good for Xantia parts - a lot less than half the stealer total price for head gasket, bolts, manifold gasket, cam belt etc etc.superloopy wrote:Think its manual tensioner, Citroën part 575138, I've checked, £90, ouch! How much tension should there be, and where on the belt?
IIRC, last I time I changed the tensioner (nearly 6 years ago) I got the auxiliary belt and tensioner from one of the local motor factors. Let your fingers do the walking...
Instructions: there is/was a link to an electronic copy of the Haynes manual on the forum somewhere. Access is from under O/S/F wheelarch (remove lower inner part of liner) and it's pretty simple. This Diagram for belt is for A/C set up; non-A/C the tensioner is in the same place but the belt misses out the A/C compressor.
Xantidote
- x 4
For the manual tensioner, where you haven't got the fancy tool, Haynes gives 5mm deflection at mid-point of longest belt run between, which I take as the bottom length of belt between hydraulics pump & crankshaft pulley - I use a firm thumb pressure to deflect the belt. If too slack, belt will scream under load, but avoid overtightening or you'll put excess load on alternator bearings etc. A bit trial & error, but I've found it works
Martin
