Xantia 4.5mm hydraulic pipe
eye_flys
Unread post by eye_flys »
I bought my cheap Xantia TD estate last year, it's been really reliable so far, until I noticed a pool of LHM under the rear nearside.
It's the pipe that travels from a 3-way union, over the rear suspension subframe and to the engine bay. Most of it is in good condition, just the rear 50cm or so is grotty. The route into the engine bay is confusing and I can't work out which pipe goes where. #-o I'm a bit stuck now...
Does anyone on here make 4.5mm pipes?
1996 Xantia 1.9 TD SX estate - happily running on veg oil
citroenxm
Fallen Hero
x 70
Re: Xantia 4.5mm hydraulic pipe
Unread post by citroenxm »
Thats your rear brake supply pipe...
Where it goes depends if you have ABS or not...
If you have ABS then the pipe goes directly to the ABS valve block, just ahead of the LHM tank..
If it doesn't have ABS, I THINK it goes directly to the 4 or 5 way connecting manifold, on the bulk head, which goto the brake valve.
The pipe runs over the top of the front subframe, and joins the grouped pipes running UP to the back of the engine bay then branch of to where they need to go, in your case with ABS to the ABS block..
I have stocks of aleady removed pipes from other cars, so I swap a whole pipe to a car.
As for removing yours, you will need to lower one side of the subframe to gain better access to the pipe, and to remove it.. However, with any luck you need to be sure the pipe union will undo, my experiance is rusted untions and rounded heads, then trouble.
Lowering the subframe is not too daunting, but the car MUST BE SECURLY SUPPORTED !!
Theres only two bolts each side holding the frame on...
A very sad...
1994 XM 2.1 d auto
