Evening all,
Quick question for you, is the brake fluid separate to the hydraulic system with the C5, and if so what fluid spec is advised. Im so used to the Xantia so want to make sure I make no mistakes! Also what is the interval for a LDS change? Thinking it may be time to get it done.
Cheers all.
fluid change intervals
ankou
Citroen C5 2.0 VTR 2007 ........ My daily smoker
Citroen Saxo 1.6 VTS 2002....... under the stewardship of my missus :/
dnsey
- x 19
Re: fluid change intervals
C5 brake fluid is DOT4.
I don't think an LDS change interval is specified, but seem to recall that the suspension is supposed to be serviced every five years, which might imply a fluid change.
ankou
Thanks for the heads up, Will sort that shortly.
