Power steering rack boot 306 hdi
Welshy_Pete
Unread post by Welshy_Pete »
I've managed to get the track rod end nut of easy. Then had a look were the passanger power steering rack boot is. There a nut on the other side I got that of as well. The rack boot will go on but now there a problem. Were the rack boot is there a bar on both sides with nuts going in them. You remove the nut of but then there a threaded pin sticking out in the way of putting the hole rack boot on the passanger side.
So I'm abit stuck now with this threading pin thats in the way at the back.
Here a example picture to the problem on the right side you see the boot then near that the nut then the power steering ram stud
link
http://www.ebay.co.uk/itm/Peugeot-306-G ... 3f21e253e9" onclick="window.open(this.href);return false;
306 hdi
thanks
Welshy_Pete
Re: Power steering rack boot 306 hdi
I found this online after having a search around for awhile.
Firstly remove the trackrod, then undo the ram nut and remove the ram, once these are out of the way remove the old gaiter, the new gaiter was bought from local partco store, a universal gaiter which is more stretchy than the genuine part. The new gaiter was left in boiled water for a few minutes just to make it even more flexible, slide the gaiter onto the rack upto the stud bolt, now this is where patience is needed, stretch the first part of the gaiter over the stud l found putting a spoon inside the gaiter and onto the stud head stopped the stud piercing through, once the gaiter has pasted the stud it was just a case of securing the ends with cable ties (supplied in the kit) and reassembling ram and trackrod. The whole job took me 2 hours, alot quicker than taking out the power steering rack.
Hope this helps someone doing a similar job.
x 94
Unread post by citronut »
yep thats why we told you to buy a rubber after market booty Pete,
imagine trying to get an OE thermo plastic one over that spigot :twisted: :wink:
Regards, malcolm.
Lighty
x 34
Unread post by Lighty »
Funny, I got a call from a local fast fit centre today, asking how to change the boot on a Picasso.
I should have told them to remove the rack. :twisted:
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Welshy_Pete
citronut wrote:yep thats why we told you to buy a rubber after market booty Pete,
Very true in what you said.
So its a spoon or something that can protect while going over it.
