Does My Ride Height Look High In This?
x 8368
I can't help thinking the front does...
Thoughts?
x 94
Re: Does My Ride Height Look High In This?
Unread post by citronut »
it looks fine to me hun,
i usually judge it by the line of the sill to the ground, spoz that dosent work if the hole car is to high/low
i think it may be the XM's body lines causing and optical illusion :bouncy: :eye: :spineyes: :wink:
Regards, malcolm.
x 3306
I see what you mean. Silly question (but sometimes a silly question nails down the problem), but are the tyres the right size for the XM?
x 8368
As far as I know they are James.. 295/60 R15. Same as a Xantia V6 on alloys...
The view from Club-XM is that she's riding just a tad high at the front. I'm told the chrome trim should be level with the top of the wheel...
I need a ramp now to adjust it...
robin92
Re: Sv: Does My Ride Height Look High In This?
Unread post by robin92 »
295?:)
Xantia Activa 2.0 tct -96, Xantia Activa v6 - 00
Sorry for my bad English;)
x 8368
robin92 wrote:295?:)
Sorry. Fat Finger Syndrome... 205/60 R 15 it should be...
Northern_Mike
Have ramps will travel for tea.
x 8368
Northern_Mike wrote:Have ramps will travel for tea.
Sounds like a deal to me :wink:
Citroenmad
x 110
Unread post by Citroenmad »
Its perhaps look a little on the high side, in that picture anyway but by a fraction of an inch if so. I'd also same the rear is high by the same amount?
Im surprised the V6 doesn't use 205.65.15 tyres, I think the 2.5TDs do.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 8368
Citroenmad wrote: Im surprised the V6 doesn't use 205.65.15 tyres, I think the 2.5TDs do.
Chris, that's a very good point :!: I've always had a feeling they look too small....
I will check!
addo
Sara Watson's Stalker
x 95
Unread post by addo »
The 605 used 205/65/15 as well - with a fairly stout load/speed rating (that makes them hard to find here, as most tyres of that size are not correctly rated).
x 8368
Chris :) It does have the wrong size tyres. 205/60 rather than 205/65 :evil: :evil: :x
I'm going to swap them for the right ones but keep the wrong ones as they are Xantia size... I'm bloody annoyed though...
addo
x 95
Make sure it's 94V in the replacements. I'd personally suggest Falken 912s if it's a dry weather car.
x 8368
Re:
addo wrote: a dry weather car.
No such thing in the UK Adam :roll:
x 1452
Re:
Unread post by xantia_v6 »
addo wrote:Make sure it's 94V in the replacements. I'd personally suggest Falken 912s if it's a dry weather car.
I have had Fallen 912s on my Xantia, and they were OK. I also have them (205x65/15) on my e type, as there is not much choice in that size v-rated. last year I needed 1 replacement after a puncture, and the 65s were out of stock in the UK, with no date for new stock.
