lexia 3
Robert12
lexia 3
Unread post by Robert12 »
Thinking of getting one of these lexia 3 eBay item number 300864955576 any thoughts on the item thanks
Ben82
x 7
Re: lexia 3
Unread post by Ben82 »
It looks like you might have the same C5s that wideboyno1 has, he had issues with reading some ECUs with the one he purchased from eBay.
People here would suggest Jim @ easydiagnostics, but you're looking at £120 from him (you get a £10 discount (to £110) if you mention you're from FCF). However you could contact the seller first and state you've heard of issues with reading some ECUs of the C5 with some of the chinese clone lexias, and would they provide a *full* refund if you encounter those issues.
If they will then it's probably worth going for it.
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
den169
Re: lexia 3
Unread post by den169 »
I'm thinking of getting this ,He's sold a lot more and good feedback also a bit cheaper then the one you posted.item 221189007865
MonkeyMark
Re: lexia 3
Unread post by MonkeyMark »
That's seems like another to keep an eye out for
It's a shame it's so hard to tell which of the eBay ones are good and which are not not.
Happy(ish) C8 owner.
Gingerposer
x 6
Re: lexia 3
Unread post by Gingerposer »
I've just ordered from the seller Den169 posted - I'll report back once I've received and tested it with my Xantia, probably put myself on the Lexia map cos i don't think there's anyone on it north of Glasgow - but there are surely a few members up near Aberdeen who could use a shot of it.
Robert12
Re: lexia 3
Just waiting for eBay seller to get back to me to see if it works on all c5 ECUs
den169
Re: lexia 3
I asked the one on ebay i posted above ,He said it works fine on the c5.
Robert12
Re: lexia 3
Just ordered from the seller den169 posted, as the guy I found can't guarantee it working on a c5 and won't do refunds
Gingerposer
x 6
Re: lexia 3
Mine arrived today, I have a quick question - seller says it will work under Windows 7 - before I try, can anyone confirm this or will I need to try and get hold of XP instead?
Ben82
x 7
lexia 3
Gingerposer wrote:Mine arrived today, I have a quick question - seller says it will work under Windows 7 - before I try, can anyone confirm this or will I need to try and get hold of XP instead?
Diagbox works on Windows 7, but Lexia does not, best to go with xp
I may be thinking of 64bit win7 here too, have no experience in trying it on 32bit win 7 but tbh that's rarer than 64bit win 7
Gingerposer
x 6
Re: lexia 3
I have plenty of free memory on the laptop so I think I will install xp on a separate partition and then put the lexia on there.
Mandrake
x 695
Re: lexia 3
Unread post by Mandrake »
DickieG has reported that Lexia (from the recent Diagbox versions) works in 32 bit Windows 7, I think the issue is just 64 bit windows of any variety.
As long as you have a recent version of Diagbox 6.xx that includes Windows 7 ACTIA USB device drivers (or download them separately via scarymistake's links) it should work.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
Gingerposer
x 6
Re: lexia 3
Update: I was struggling with the installation last night so I contacted Artur (the seller) who dialled in using Teamviewer to see what he could do. He recommended installing a Microsoft plugin called XP Mode (for Win7) however this requires some kind of genuine windows validation thing which for reasons I won't mention here I wasn't really keen to try. So, I have wiped the laptop and am doing a fresh install of XP to see if I have more success.
Robert12
Re: lexia 3
Got my lexia3 today installing it via remote
Ben82
x 7
Re: lexia 3
Gingerposer wrote:Update: I was struggling with the installation last night so I contacted Artur (the seller) who dialled in using Teamviewer to see what he could do. He recommended installing a Microsoft plugin called XP Mode (for Win7) however this requires some kind of genuine windows validation thing which for reasons I won't mention here I wasn't really keen to try. So, I have wiped the laptop and am doing a fresh install of XP to see if I have more success.
Probably was a bit extreme, XP Mode is generally only for the Corporate or Ultimate editions. However any free Virtual Machine software should have done fine (VirtualBox, VMWare etc) without the need of wiping. :) ( They don't require a genuine copy of windows either ;) )
I personally use VirtualBox for mine with no issues (on my Genuine Home Premium Edition of 7 64bit).
