Xantia heater plugs
froggy
(Donor 2026)
x 4
Xantia heater plugs
Unread post by froggy »
Hi, I need to change the heater plugs in my 1997 Xantia. It looks more of a challenge than my faithful old ZX. Iam wondering which are the best plugs to buy( should it be Citroen only) and do I need to buy a specialist tool to help me reach these blighters! thanks in advance Terry. :?:
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
x 94
Re: Xantia heater plugs
Unread post by citronut »
read the thread in link below might help
http://www.frenchcarforum.co.uk/forum/v ... =3&t=43434" onclick="window.open(this.href);return false;
also if you use Beru or NGK from the likes of GSF you cant go far wrong
just stay well clear of cheap branded/fake or just plane cheap from ebay and the likes of E*C*P
Regards, malcolm.
evilally
x 3
Unread post by evilally »
I've just removed a set of NGK from my 406 which have probably been in for at least 3 and a half years. They were shagged out but in solid condition. Cheap no name ones can swell up at the tip then break off when you try to remove them, been there, done that :twisted: 8mm and 12mm flexi ratchet spanners are your best friends here, and possibly a small person with little hands for the one behind the pump.
'97 406 1.9TD, 314k.
froggy
(Donor 2026)
x 4
cheers! :)
Terry
Johnny Cogs
Unread post by Johnny Cogs »
You'll need a clean towel too froggy, to keep your hands oil free when trying to put the 8mm nut on top of the second plug in from the cambelt side.... Nasty piece of work that one is!!! Also, dont throw away the 8mm nuts from the old plugs...... just incase!!!
'rolls in a 1.9TD Syn-bus!'
spider
x 77
Unread post by spider »
Magnetic telescopic extension can be useful, although one that has a protector on it ie it does not stick to the sides ;)
Or a flexi claw may help. Its usually the difficult one that's failed because in the past someone 'forgot' to change that one...
Agree about the 8mm nuts, they have a habit of going for a wander behind the pump bracket amongst other places. I found a penny coin behind mine. :D
Andy.
