1.9 TD Throttle Damper
Gregg1100
- x 5
This Xantia 2 has a throttle damper that takes a while to let the revs go back to tick over. Can this be removed, please? Or have I got to fit a stiffer return spring??
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
Xantidote
- x 4
Re: !.9 TD Throttle Damper
Mine, an earlyish Series 1, had the black tubular damper fitted, and it did exactly as yours, taking a few seconds to drop to tickover - a bloomin nuisance. Just remove it, and the revs should drop immediatelyGregg1100 wrote:takes a while to let the revs go back to tick over
Martin
1995 Xantia TDLX (deceased
Gregg1100
- x 5
Thanks Martin. Appreciated.
- x 94
bin it, its only there for emission control so we are told, its meant to let the revs drop gently
Regards, malcolm.
- x 1240
Re: 1.9 TD Throttle Damper
Most of them have been by now.
spider
- x 77
Confirmed, same as the 406TD ones, most owners threw them away as they tended to wear and rattle annoyingly sometimes too. Did not in most cases need any anti stall adjustment either. They are surprisingly expensive new from the dealer too.
Andy.
