Peugeot 307 2003 2.0 Hdi Brakes
floggmolly
Unread post by floggmolly »
I Have A 2003 Peugeot 2.0 Hdi. A Steel Brake Pipe Burst And I Lost All Of The Fluid, I Bled It At All Four Wheels But I Couldnt Get Brakes Back On It. I Changed The Master Cylinder And I Still Cant Get Brakes On It. What Could Be Wrong?
Lighty
x 34
Re: Peugeot 307 2003 2.0 Hdi Brakes
Unread post by Lighty »
Some brake systems can be terribly to do manually, we recently did a 307cc for a local fast fit place that had your problem.
Our high pressure brake billed machine is the key, we had the 307 done in 20 mins, it just seems to purge places that other methods can't reach.
There is also a program for bleeding the car on Peugeot Planet, this operates the ABS solenoids, to bleed the system correctly.
We did not require this on the 307, just be aware it is there.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
x 94
Unread post by citronut »
floggmolly wrote:I Have A 2003 Peugeot 2.0 Hdi. A Steel Brake Pipe Burst And I Lost All Of The Fluid, I Bled It At All Four Wheels But I Couldnt Get Brakes Back On It. I Changed The Master Cylinder And I Still Cant Get Brakes On It. What Could Be Wrong?
what method did you use just the up down up down up down up down method, or an easy bleed
Regards, malcolm.
floggmolly
I used a bleeding tool. There wasnt much pressure from the bleed scews. Where do i find the bleeding operation on peugeot planet?
Lighty
x 34
It will be in the ABS section under actuator tests (I think)
Citroen C15
Citroen Ami
