Got the shock of my life when he asked me for £39.95 for 4! And that was trade price btw, they retail at £12.49+VAT! Anyway I threw my credit card at him and went round to my mates workshop to fit them. Did the easy three and couldn't really be bothered doing the one behind the pump as I was ready for my tea so I left it.
Tried to start the car - it started after about 20 seconds cranking with a plume of smoke and sounded rough as hell for about a minute - previously it was slightly rough for about 10 seconds then went fine.
Tried starting it a few times that evening and it was crap - worse than its ever been! These things are worse than the 1997 Lucas plugs that look well past their best I took out. The following morning it was horrendous to get going and ran awfully rough.
Rang my Dad and asked him to get me a set of Beru from GSF Liverpool. They didn't have them, so I ended up getting them today. Started the fitting process about 6pm tonight, and feeling brave I thought I'll do the hardest one first!
Got the little nut off and the wire off easily, but there was absolutely no way I could get a spanner - ring or open ender - on the plug as the coolant pipe was bent around the plug about 3mm away. Had a think and decided there was no way it was coming off without the pipe coming off first. Dave Burns had warned me about this in another thread but there was no other way to do it. Took the pipe off which was easy enough bar the fact about 2 litres of coolant poured onto the garage floor. Took a spanner to the plug and would it budge - would it heck!
Decided to give the spanner a real hard pull - plug moved and then a sharp twanging noise. Looked around and finally spotted the bloody pipe fitting for the little coolant pipe had sheared off as the spanner hit it. I was more than a little pissed off I'll tell. Still not to worry, on with removing the fitting so it can be replaced. Top bolt came out after a bit of a soaking of WD40 and a bit of pipe over the end of the allen key for leverage. Bottom one is impossible to access from the front, and after mangling the 4 6mm Allen keys I had I gave up and took my frustrations out on it firstly with a cold chisel, then a long screwdriver, then a set of mole grips, then a wood chisel and then the screwdriver again. After about an hour it started turning and I have finally managed to get the mangled mess out without any long term damage to the cylinder head.
I will have to make a hopeful call at 7.30am tomorrow to the parts department at the dealer I use who will hopefully have the fitting, gasket and 2 bolts I need on the shelf. I can't imagine im the only one to break one of these (am I?
So far the exercise has cost me £39.95 for the NGK plugs, £30.55 for the Beru plugs and the parts I need tomorrow come to about £25.00 so thats £95.50 for the job plus about 5 hours labour. Wish I'd sent it to the Diesel specialist who quoted me £70 all in now!
