c5 sx 2ltr diesel heater blower on at all times
tonymike
Hi I have acitroen c5 sx the heater blower cannot be controled by the switch,and is on full power at all times,any help would be appreciated.thanks tonymike
Citroenmad
- x 110
Re: c5 sx 2ltr diesel heater blower on at all times
That will almost certainly be the resistor pack, which is loccated to the left of the clutch pedal on a RHD car. About £85 from Citroen if I remember corectly, try ebay for a cheaper but new one.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
tonymike
Thanks for info about resistor pack, how dificult for a 77 year old codger to remove old one,and to fit a neww one???many thanks tonymike,
Citroenmad
- x 110
Its very easy, if you remove the panel to the left of the clutch pedal it is just in there. i think there is a green connector on it. It is held in with a few screws which is the most fiddly bit to do
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
tonymike
Citroenmad,thanks for the info,when the weather gets better,and warmer I will have a go,the car is only used for journeys, not to the shops and back,thank you once again,tonymike
tonymike
found out where the resistor is,i cant even feel the top screw,i think a bit of contorsionism is needed,top screw will definately NOT bacck in,thanks again, tonymike
JohnD
- x 72
When I was faced with this job on daughter's Xsara == (heater fan constantly blowing at full belt) I removed the heater entirely to replace the transistor pack. Unfortunately it only worked for a month so I got a new heater.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
