Whilst cleaning my car I got curious. Its a base model 03 C8.
The front doors have blanking plates where lights would be. When I removed the plate a cable was there to plug into a light so I inserted the one from the boot, but it won't come on.
Is there a secret to getting it to come on ( does it just light when the door is opened or do you have to have headlights on too) or is it a case that the wiring will be incomplete and lead to nowhere? I don't really fancy removing the door card just to find out as it was a pig to put back on last time.
EDIT: Does the light in the glove box ever go out? Just put a new bulb in and it looks like its on all the time.
C8 door lights
miked
- x 6
Re: C8 door lights
I've just been out, unlocked the 807 and opened the door and the light above the door pocket lit up. So no need for headlights.
The glove box light only came on when I put the ignition on, but I honestly can't tell if it goes out or not when the lid shuts. Actually I wish you hadn't asked
It won't be tonight but at some point I'm going to have to shut the camcorder in there while it's recording to satisfy my curiosity.
MonkeyMark
Re: C8 door lights
Thanks for the effort. Much appreciated.miked wrote:I've just been out, unlocked the 807 and opened the door and the light above the door pocket lit up. So no need for headlights.
The glove box light only came on when I put the ignition on, but I honestly can't tell if it goes out or not when the lid shuts. Actually I wish you hadn't askedIt won't be tonight but at some point I'm going to have to shut the camcorder in there while it's recording to satisfy my curiosity.
And the thought that it's going to drive you nuts till you find out makes me chuckle.
So then, the question is: is my wiring incomplete? Or do I need to find out what the problem is? Any idea which fuse it runs from?
Happy(ish) C8 owner.
miked
- x 6
Re: C8 door lights
The handbook makes no mention of interior light fuses other than fuse 12 "courtesy lights." I'll pull it out after work tomorrow when I can see what I'm doing and let you know.
MonkeyMark
Re: C8 door lights
OK thanks.miked wrote:The handbook makes no mention of interior light fuses other than fuse 12 "courtesy lights." I'll pull it out after work tomorrow when I can see what I'm doing and let you know.
If its running from the same fuse as the other courtesy lights and the glove box then I presumes its not connected somewhere else. That's a shame.
- x 3296
Re: C8 door lights
I wonder if this is something that would be set up via a Lexia?
MonkeyMark
Re: C8 door lights
Well I am looking into getting a lexia anyway, so that would be another good excuseHell Razor5543 wrote:I wonder if this is something that would be set up via a Lexia?
That reminds me, want to find some instructions or similar for the lexia to give me an idea what it can be used for.
miked
- x 6
Re: C8 door lights
Well, I pulled fuse 12 out, and all the interior lights stayed on. So I tried fuse 4 "Supply to functions via the built-in systems interface" and it's not that one either.
If you have time yourself to figure out which fuse does the roof lights I'll give it another go.
They certainly don't come on and go off at the same time as the lights in the roof. They go out when the door is shut even though the roof lights stay lit. And with the door open they stay on when I turn the ignition on (when the roof lights go off).
MonkeyMark
Re: C8 door lights
Ok, thanks for trying.
Reading through some other threads I came across someone (sorry can't remember who) trying to get to grips with a lexia and the option to switch on door lights was mentioned. So perhaps yes, it is something that could be altered, albeit with the right equipment.
If that is the case, then the reasons for buying said right equipment are adding up.
