Servicing and Care...
ankou
Unread post by ankou »
Evening all,
Quick question for you, I want to get the C5 serviced, its 5 years old and has covered only 28k. What service would you advise and also what is the intervals and service types for this car, only had it two weeks so very new to this!
Thanks in advance
Citroen C5 2.0 VTR 2007 ........ My daily smoker
Citroen Saxo 1.6 VTS 2002....... under the stewardship of my missus :/
oneday
Re: Servicing and Care...
Unread post by oneday »
what engine petrol diesel?
306 1.4 LX MERIDIAN
ankou
2.0 petrol, sorry I forgot to mention it!
oneday
as far as i can make out it should have been serviced about 3 to 4 thousand miles ago service intervals 12000 miles and it should be just a basic service oil filters and so on hope this helps
306 1.4 LX MERIDIAN
ankou
The car has barely done any miles since its last service at 23k in june 2012, just want to make sure its done earlier rather than later :D and thank you for the heads up.
blackbeard
Unread post by blackbeard »
Servicing is time dependent not just mileage dependent. My C5, although a bit older than yours is the 2.0 16v petrol which I think has the same engine as some of the later models. The service interval is 20000 miles or 12 months - whichever comes first. In addition to the 'standard' service intervals there are also time dependent additional checks and repacements, such as timing belt check/replacement, coolant specific gravity check/replacement, and brakefluid replacements etc. They are all dependent on driving conditions/style as well as mileage and age.
A Citroen independent (or a Haynes manual) should give you a bit more info on your particular model.
Ps, rear calipers need particular attention as in all but tow cars they tend to be under used and are prone to corrosion - or even seizing if not serviced properly.
Current French machine:
2002 Citroen C5 2.0 16v Automatic (petrol)
Previous French machines (all auction finds):
2000 Citroen Xantia 1.8 16v (petrol)
1999 Peugeot 206 'Roland-Garos'
1998 Renault Laguna 1.8 8v (petrol)
1992 Renault 21 2.0 8v (petrol saloon)
triumphtoledo
Unread post by triumphtoledo »
Post-facelift C5s did not have the direct-injected HPi engine and so the units are not the same...
R
