Hi!
Have a C2 2004 (145000km) with all software updates installed but with a Sensodrive problem...
When driving and changing gear i somtimes (without logic: 4 times a day or 1 time a week) get the snowflake-warning for the gearbox and one of the following happens:
1. When slowing down the gearbox shift down and the error resolves itself and i can continue driving.
2. When slowing down the gearbox isn't changing but declutch when i stop and then just revs. Unless i rev it to approx 3500-4000rpm when it jumps forward.
3. When slowing down the gearbox isn't changing and wont declutch so i have to brake it to a forced engine stop.
I've checked with the Lexia and there is 1 permanent error each time: P1755 "Clutch actuator fault: Incorrect position in relation to the reference value. Coherence"
Could it be the clutch actuator that's finished. Or do I get these errors due to a clutch problem. Or is it just electrical issues?
(I do get some electical temp errors that isn't showing each time
P1804 Transmission 4-Wheel Drive High Indicator Circuit Failure
P0744 Torque Converter Clutch Circuit Intermittent
P0811 Clutch overheating fault EGS Gearbox
P0750 Shift Solenoid A Malfunction
P1702 TRS Circuit Intermittent Malfunction )
Have anyone seen this before or have any ideas what to try?
Hepl needed!
P1755 Clutch actuator fault: Incorrect position
Lighty
- x 34
Re: P1755 Clutch actuator fault: Incorrect position
I changed a clutch actuator this week that had exact same fault. I wasn't sure so fitted a used one 1st, but it rectified the fault straight away. £360 + vat for a new one
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
MarkusC2
Ok, tanks!
Do you think its any idea to buy a used one or is it just to pay up for a new?
If I should by a used one, is there alot of different specs and i have to find the right one?
How hard is it to change - special tools except Lexia?
Regards, Markus
Regards, Markus
Lighty
- x 34
I personally would fit used, I don't think there are any different models. I may be doing it all wrong, but each time I remove one, we invariably end up stripping it to get it into the "off " position. Have done it with the Lexia a few times, but they always seem to come out a bit.
Anyway Iam an expert at rebuilding them now
To fit you will need to remove battery box and air filter, which is a battle in itself. There are 3 Torx screws, undo the a little and the unit slides off.
Then you program it all up with the Lexia. This sometimes takes a few attempts , it doesn't seem to be an exact science , but I don't think it will reprogram with faults in.
Trouble is we don't do them often enough to get a good system going, often there is a month or two inbetween cars, and at my age you forget the routine.
We always use the battery charger on the car to maintain over 12.5 volts whilst programming.
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
MarkusC2
Found http://ww2.justanswer.com/uploads/nabil ... 12_cas.pdfdescription on how to change the actuator - have you done it without the pre-load adjustment?
