Saxo Rear Fog Lamps
redsaxo
Saxo Rear Fog Lamps
Unread post by redsaxo »
Hi
It was brought to my attention recently that the rear fog lamps on my recently purchased Citroen Saxo were not working. Investigation showed that the previous owner had removed the bulbs . . . Being suspicious I thought that there was probably a good reason for him doing this. Having fitted new bulbs I have found that reason! The rear fog lamps are now lit permanently whenever the ignition is on!
Any ideas welcome.
Thank you
Red Saxo
x 5672
Re: Saxo Rear Fog Lamps
Checking the switch might be a good place to start.
Fused contacts or a broken spring being likely suspects.
redsaxo
Thanks for that - will investigate the switch tomorrow and post pics of car in due course.
