2.2 hdi injector removal
horsedentist
Unread post by horsedentist »
Has anyone got any tips for loosening the injectors on a 2.2 HDI. I don't know how badly seized they are but I want to remove the ones from my scrap 2.2 and put them in the one I am using. I have filled the well around the injectors with plus gas and currently letting them soak in the hope that this may help. I haven't tried very hard to get them out but they are not loose enough to move with a screw driver. I understand they may be seized solid and need an extractor to remove them but thought I would ask the question before I started struggling.
qprdude
x 14
Re: 2.2 hdi injector removal
Unread post by qprdude »
If you have access, using a blunt nosed punch, tap round the injectors . Not to hard as to crack anything, but hard enough to "shock" the threads and allow the plus gas to penetrate. Don't use a big hammer on the punch and you wont overdo the shock. We used to use what we called a "toffee hammer" and a 6-10 mm parallel punch.
Rick.
2013 Citroen DS 5 D/Sport
horsedentist
qprdude wrote:If you have access, using a blunt nosed punch, tap round the injectors . Not to hard as to crack anything, but hard enough to "shock" the threads and allow the plus gas to penetrate. Don't use a big hammer on the punch and you wont overdo the shock. We used to use what we called a "toffee hammer" and a 6-10 mm parallel punch.
Its not the threads as such it is the injectors in the sleeves in the head?
HaydnR
Unread post by HaydnR »
I only had one seized on mine and managed to remove it by undoing the studs alternately 1/2 a turn at a time.
'02 c5 2.2 hdi exclusive
horsedentist
HaydnR wrote:I only had one seized on mine and managed to remove it by undoing the studs alternately 1/2 a turn at a time.
I will try that then cheers
KevMayer
Unread post by KevMayer »
As far as I understand the injector is usually stuck because of carbon deposits around the stem caused by 'blow by' of combustion products past the copper sealing washer.
The link below is from a site which recommends a cleaning solution to disolve the carbon. It's a product called 'Turbo Clean Set' by a company called Innotec. You can get it on ebay at around £39 for the 5 piece cleaning set.
http://www.uniteddiesel.co.uk/tips_docs ... low-by.pdf" onclick="window.open(this.href);return false;
Cheers, Kev
waynedance
x 8
Unread post by waynedance »
recently removed mine and none were stuck at 90k.
Volvo S80 D5.........
c.morewood
x 55
Unread post by c.morewood »
I use paint thinners to loosen the hard carbon on the C2. It worked pretty well.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
SaabC5
Unread post by SaabC5 »
Get a large ladle and put some clean engine oil in it, heat it underneath and then pour a small amount into each injector hole. This will sizzle clearing all the crud from around the injector base, allow to cool and then have a go at removing the injector.
