Hi
In the following link there is a pic of the hydraulic pump assembly.
http://imageshack.us/photo/my-images/24" onclick="window.open(this.href);return false; ... esized.jpg
With respect to the above pic , does part #3 ( ring ) orientation is correct. In my Xantia the pump was removed and it looks like part #3 is inserted to the bracket inside out i.e. the ring shoulder (part #3) is between the pump body and bracket , as oppose to the pic at which the ring shoulder is between the bolt head and the bracket. I checked it with two other Xantias and it is assembled the same way as my Xantia , but it may that in all Xantias the pump was detached and assembled in the wrong way
Regards
Zohar
Xantia – Help needed correct assembly of hydraulic pump
lancia58
- x 8
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
lancia58
- x 8
Re: Xantia – Help needed correct assembly of hydraulic pump
Can anyone help with this ?
Zohar
Zohar
Mandrake
- x 695
Your image link is broken...
I've had the pump out of my previous Xantia, in fact I stripped the pump right down but its years ago now so I can't remember small details like the orientation of spacers...
Also there are many variations of the hydraulic pump and mounting bracket depending on year, engine model, A/C fitted or not etc, so nobody is going to know unless we know these details.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
lancia58
- x 8
Hi
The car is 2.0 V16 make year 200o with A/C. The photo I provided the link to is from Citroen Service per my Xanti's VIN number. Can't you use the link ? At least from my computer when I click it the image appears .
Regards
Zohar
Regards
Zohar
addo
- Sara Watson's Stalker
- x 95
lancia58
- x 8
Thanks Addo
Yes that's exactly what I speaking about. Can you upload close up photos of the upper and lower spacers. BTW I tried to upload photos I took and they didn't show up (only a small blank square with "Image" written in red ) , can you explain how to upload photos, so I can upload the photos I took.
Thnaks
Zohar
Thnaks
Zohar
- x 5671
lancia58
- x 8
Thanks I'll try it
lancia58
- x 8
Re: Xantia – Correct assembly of hydraulic pump - with photo
Hi
In the following link there is a pic of the hydraulic pump assembly as copied from citroen service per the VIN of my Xantia.
Pic of upper bolt
Pic of lower bolt
I checked it with two other Xantias and it is assembled the same way as my Xantia , but it may that in all Xantias the pump was detached and assembled in the wrong way.
After the pump was attached I found the following nut on the AC, it looks like part #4 in the assembly , is that correct
Regards
Zohar
Pic of upper bolt
Pic of lower bolt
Regards
Zohar
addo
- x 95
I was incorrectly informed by the Service Citroën illustrations, too.
The way these parts work, is what I call "slip and grip". The flanged sleeve is free to slide left or right until you tighten the bolt/nut with a conical face - this cone expands the sleeve and locks the part into position just like a masonry bolt.
My pump has remained perfectly aligned since I refitted these parts in the correct order (using sense, not the illustrations). It's a little bit dark now to get a good clear picture, unfortunately.
lancia58
- x 8
Hi Addo
If you look at the pic I named "Pic of lower bolt" ( third one ) it looks like the mechanics used to wrong nut , and the nut should be switched with the one I found on the AC compressor took its photo ( last photo ) right ?Once you will have daylight I'll appreciate if you can post a photo of both bolts used to attach the pump to its bracket ( the bottom one is a bit difficult to take its photo )
Regards
Zohar
Regards
Zohar
lancia58
- x 8
Hi
I replace the nut that secure the lower bolt with the one I found on the AC Compressor ( part #4 ) and the rattles disappeared
Zohar
Zohar
