My car (03 C8 2HDi) was recently hit in the rear.
Since then it shows airbag fault.
The garage (not a Citroen garage) said they could not see that fault but the could see:
BSI (injectors?)
Air con climate regulator (though it seems to work fine)
LED dashboard
This is all i was told. Can anyone shed any light on this or is there anyone in the Durham/Hartlepool or near area's that could hook it upto a tester (are they called Lexia's?) for some beer tokens? (or how do I purchase a tester as i intent to keep the car for a good while)
Cheers, Mark
Faults after a collision - advice please.
Happy(ish) C8 owner.
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1206
Re: Faults after a collision - advice please.
Hi Mark
The wiring connectors under the front seats can give a false airbag warning but if they can't find a fault anf the light is not on I wouldn't worry about it. If you connect an analyser it will always show up some faults, all that means is that there was a fault not necessaraly that there is now, so if you don't have any warning lights and everything seems to work OK don't worry about it.
if you feel you rquire a DIS-LEXIA hook up check the link for location map
http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178" onclick="window.open(this.href);return false;
Regards, malcolm.
Thanks for that.
The airbag fault is showing lights, and warns on the LCD display each time the ignition it turned.
Using the dissable option, for when using child seats, seems to make no difference.
In the past there has been water in the drivers footwell which I'm still trying to find the cause of (I may have worked this one out, time will tell) this could be to blame.
As for the injector fault.
In the bad weather I hit flood water (dark road and didn't see it) and it ripped off a cowling going around what I think is the diesel cooler or pre heater or similar. That could be that one I suppose. It bent the bracket that bad I'm not sure how it goes back on. ( pictures anyone?).
- Donor 2023
- My Cars: Peugeot 504 2.0 diesel 1984 (built in South Africa)
Peugeot 505 GTI 1986 (built in South Africa, and brought to Britain 1988)
Citroen XM V6 (UK)
Citroen Xantia 2.0 HDi 1999 (excellent car but it ate suspension spheres)
Citroen C5 2.2 HDi Exclusive Auto 2001
Citroen Grand Picasso II 150 HDi EAT6 Exclusive 2015 January - engine rattled until replaced. Gave it back at 1600 miles.
Citroen Grand Picasso II 150 HDi EAT6 Exclusive 2015 July - still going strong - x 4
Hi. I would like to contact one of your DIS-LEXIA owners who lives near me, and I have looked everywhere except the right place for instructions on how to do thatcitronut wrote:if you feel you rquire a DIS-LEXIA hook up check the link for location map
The person I am looking for is DURACELL. Can you, or anyone else help me?
If DURACELL sees this, please feel free to contact me directly by email.
2015 (Jul) C4 Grand Picasso 2.0 Bluehdi 150 EAT6 Exclusive+ now running on 17" wheels - SO MUCH MORE COMFORTABLE AND SMOOTH THAN 18" - AND better fuel economy
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
I dont think duracell has logged in for a while..
You be better off going to your message tab at the top left and composing a direct private message to him.
Just put his user name in the add box and write a message. He will then get an email to his personal email box telling him he has a message..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Ben82
- My Cars: C5 V6 2004
- x 7
If you don't have any luck with Duracell, I'm up in Gravesend for the next week, and I think h2ocooler is in the medway towns.WillyR wrote:Hi. I would like to contact one of your DIS-LEXIA owners who lives near me, and I have looked everywhere except the right place for instructions on how to do thatcitronut wrote:if you feel you rquire a DIS-LEXIA hook up check the link for location map
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
or just click on his user name then click the "send private message" buttoncitroenxm wrote:I dont think duracell has logged in for a while..
Paul
Regards, malcolm.
- Donor 2023
Citroen XM V6 (UK)
Thanks. I searched everywhere last night for that but failed - not used to this forum layout yet. I'll try him now.citroenxm wrote:I dont think duracell has logged in for a while..
Paul
