Having just about got to grips with the Lexia its now stopped working, computer says it can't connect to it although the light is on, any suggestions?
Lexia problem
red_dwarfers
- x 58
Re: Lexia problem
The first thing I would check is drivers. If I remember correctly, it's Windows XP you have isn't it?
Click on start and Run. Type in 'compmgmt.msc' in the box then click ok. This will bring up Computer Management. On the left hand pane/section click through the menus 'System Tools' and 'Device Management'. Plug the Lexia in. Does the page refresh? Do you get any question or exclamation mark symbols?
Kev
'19 C4 Cactus 130 Flair
- x 1240
Re: Lexia problem
I will check Kev, thanks.
Citroenmad
- x 110
Re: Lexia problem
The copy Lexia can be a frustrating thing! I've often embarrassed myself when going out to someone’s car only to spend 30 minutes getting the thing to work!
Make sure you are using the USB which was used when the Lexia was installed. Also, always make sure the USB is plugged in before the laptop is turned on. They are the usual causes for connection problems.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 1240
Re: Lexia problem
Thanks Chris. Yes, I am using the original port although I have tried it in the other one just in case. It says 'something else may be using the programme'? Its never done this before, it happened after I had inadvertantly left it switched on for a couple of days.
DickieG
- Monaco's youngest playboy
- x 33
Re: Lexia problem
You're right there Chris, mine started playing silly buggers last night so I dug out my Lexia 2 to get the job done.Citroenmad wrote:The copy Lexia can be a frustrating thing! I've often embarrassed myself when going out to someone’s car only to spend 30 minutes getting the thing to work!.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Mandrake
- x 695
Re: Lexia problem
Hmm, no problems with mine yet, touch wood...
Peter - are you running an old version of Lexia by itself or do you have Diagbox which then launches Lexia from within it ? On the latter I find that I always have to unplug the USB cable to my interface and reconnect it AFTER launching diagbox, but BEFORE clicking on the Lexia button to launch the actual Lexia app.
If I don't, I always get a message saying something like unable to communicate with the interface. Try that and see if it helps...
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
- x 1240
Re: Lexia problem
Simon - no I don't have Diagbox, mine is a pretty old setup. I will do the check that Kevin suggests when I get a minute, only I'm a bit busy at the moment.
Citroenmad
- x 110
Re: Lexia problem
Ah, I've had this when pressing the button to open Lexia more than once. It seems to open up in the background, though a restart should have cured that.Peter.N. wrote: It says 'something else may be using the programme'? Its never done this before, it happened after I had inadvertantly left it switched on for a couple of days.
They are not known for their reliability sadly, I've had to reinstall it a few times as it only seems to work for so long
Still, for the amount of times I use it, I can live with that.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
