disable abs on berlingo .............
bobb
Hello, i have a problem with abs system on berlingo 1.6 hdi van 2007...i need the van for work for next 2 weeks,how can i disable abs system so i have normal braking until i take van to get it fixed....looked in manual & it says fuse 3 located in engine bay is for abs....will removing this fuse disable abs & give me normal braking....also will speedometer still work if i pull this fuse......thanks............
- x 1489
Re: disable abs on berlingo .............
It should give you 'normal' braking - however, be aware that there may well not be a rear brake compensator, and that running without ABS may result in the back end locking up under heavy braking when lightly loaded, and trying to come round and meet you
this might of course be preferable to hyperactive ABS preventing the van stopping! Fitting a new reluctor ring is easy enough, so worth getting it done ASAP.
Northern_Mike
There is a compensator valve on them. They're famous for having squeaky springs.RichardW wrote:It should give you 'normal' braking - however, be aware that there may well not be a rear brake compensator, and that running without ABS may result in the back end locking up under heavy braking when lightly loaded, and trying to come round and meet youthis might of course be preferable to hyperactive ABS preventing the van stopping! Fitting a new reluctor ring is easy enough, so worth getting it done ASAP.
Sent from my GT-I9300 using Tapatalk 2
bobb
hi,thanks both for the replies & advice i.ll remove fuse tomo & see how it goes...........
