Hello,
Just wondering if anyone out there has found themselves in the position I am in. I have received my (wife's)Peugeot 206 LX 2.0 D back after having the clutch replaced for the usual reason – difficulty changing gear( I'd normally do it myself but didn't fancy laying in the snow). This came on fairly quickly, which is not unusual, with no nasty noises from the bearing. Guy said bearing fell apart when it came off and that the guide tube had to be replaced because it was in a mess. I arrived as the hub caps were going on so all ready to go. Tried clutch but found my foot down almost to the floor before able to change gear, operation can only be described as spongy and weak. Tried venting slave cylinder but made no difference. Guy in fairness to him has told me to take it back if it does get better but thinks it will sort itself out and will adjust accordingly. My guess (and reading forum) is that the clutch bearing actuator arm is bent or cracked and must be replaced. What do you think and thanks in advance?
206LX 2.0 D bent clutch bearing actuator arm?
Edhertz
- x 5
Alan
1999 Xantia Exclusive 2.0Hdi Mauritius blue
1999 Peugeot LX 1.9D silver
- x 94
Re: 206LX 2.0 D bent clutch bearing actuator arm?
as its just had a new clutch fitted it will feel different to before,
you should also need to press the pedal to the floor to fully release the clutch,
not sure so much with a hydraulic clutch if it should feel lighter affter a new clutch has been fitted, like it does with a cable clutch?????
Regards, malcolm.
Oldpug
- x 94
The bearing breaking up is common and it always damages the guide tube that your man has replaced,but,I`m very surprised the fork has not been replaced as well??? Take it back,you paid the man to fix a faulty clutch so it should work perfectly straight away,end of.
flying clutchman
- x 3
A new clutch will nearly always feel very light, especially when you've been used to the old one. Your mechanic is quite right, it will very quickly adjust to a more familiar biting position. If the clutch fork had been damaged it's virtually impossible to make it work. The bearing carrier only has tiny clips to hold it to the fork and will flip off if it's not 100%
Edhertz
- x 5
Thanks everyone for your replies - much appreciated. Looks like your comments are spot on flying clutchman. The clutch feels much more positive now after a weeks use. The mechanic thought it was unusually soft which led to the slave cylinder being vented. I can now tick the self adjusting clutch learning box.
Alan
spider
- x 77
Missed this reply when you posted it. Good to know its all sorted now.Edhertz wrote:Thanks everyone for your replies - much appreciated. Looks like your comments are spot on flying clutchman. The clutch feels much more positive now after a weeks use. The mechanic thought it was unusually soft which led to the slave cylinder being vented. I can now tick the self adjusting clutch learning box.
Andy.
