54 berlingo problem
Daz3nt
54 berlingo problem
Unread post by Daz3nt »
Hi all, since my last post I've bought a different van on a 54 plate, had to use my dw8 engine from my old van in there but have a few problems. Wipers, headlights and horn dont work The dash goes off after exactly 60 seconds, side lights and full beam work ok. I don't have a plip just normal key. I can do a bsi reset up until it says to hold the lock button down on the key but that does nothing. Checked all fuses but they are ok. Anyone got any ideas?
spider
x 77
Re: 54 berlingo problem
Unread post by spider »
Was it just the engine you changed ? Does it run ?
Did you change the BSi / ECU over ? , just thinking as a dearmoured DW8 would not in theory want the immobiliser swapping over.
I thought about the com 2000 but with various other things not working it may be something as simple as a missing earth lead somewhere especially as its been to bits for the engine swap.
Andy.
x 1060
Unread post by wheeler »
All of the non working things go via the Com2000 so it could be a good bet.
