trip comp control thingy
bill196510
Unread post by bill196510 »
The button to alter view on comp not working, is there a fuse for this
C5 2.2 hdi 2003, called it oliver reed, drinks like him :(
Good on fuel now, lol.
oneday
Re: trip comp control thingy
Unread post by oneday »
bill it will be a fault inside the the switch a metal disc that breaks. just repaired the one on mine
306 1.4 LX MERIDIAN
x 5672
A common fault. It's the button on the end of the stalk. Can be repaired but it said to be very fiddly. Button just pops out with a pair of thin probes, but so do the springs and contacts :(
bill196510
Can the bits be purchased
x 5672
bill196510 wrote:Can the bits be purchased
If you supply the last eight digits of your VIN them Malcolm may be able to give more precise information but I am of the mind that the whole of the COM2000 unit has to be replaced as the stalk is an integral part of it.
As oneday says, they are (generally) repairable as long as none of the bits escape.
bill196510
The button on end of light stalk is same as comp stalk, will it fit, whats the light one for, lol.
Ben82
x 7
Unread post by Ben82 »
bill196510 wrote:The button on end of light stalk is same as comp stalk, will it fit, whats the light one for, lol.
Only useful function I know of, is turning on/off the automatic headlights, when the key is in the first position.
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
bill196510
Will button fit though
