Clarion radiodisk connections
atr
x 6
Unread post by atr »
Hi
In my 2001 Xantia there is a Clarion radio&cdplayer. as far as I know it's its original one.
what I would like to know is which pin on the connector mutes the radio since I would like to connect it to the cellphone handsfree kit? is the connector(s) pinout can be found somewhere?
Thanx.
x 8283
Re: Clarion radiodisk connections
Hmmm. Tricky. I'll see what I can find out in the circuits. basically you need to possibly tap into the mute line that goes to the steering wheel mute button..
Sean602
Unread post by Sean602 »
pretty sure its No 2 on one of the din connectors
If its a "Parrot" then they were the factory fitted ones and so simply plug in to the loom side of the harness ( i did have to swap the 2 fused wires around orange to red and red to orange so the radio could work ign off)
http://www.tehnomagazin.com/Auto-radio- ... nector.htm
kissing the lash
white van (turbo, computer and built by Citroen, what could possibly go wrong!)
orange 2cv
blue 2cv( been to the Sahara and back)
red Dyane( in bits)
Skoda (thank goodness there is a teutonic vehicle on the drive)
Stainless Siemens fridge freezer
atr
x 6
CJ - I hope that you will come up with an answer (you're usually do) maybe it might be pin no.2 as Sean suggests. anyhow, it's not a Parrot, it's a Bury(model cc9040).
Sean602
you didnt click the link?
the greyed out bit at the bottom of my main post ....not the waffle about cars it has the info you need in the second diagram its a look at the radio side socket from which you can work out what pins do what its in German but bottom plug with the offset tag no 2 pin is the one nearest the tag and thats the mute wire
kissing the lash
orange 2cv
red Dyane( in bits)
atr
x 6
Sean- thanx. it's great!
