moaning noise after run
bill hughes
Hi I have a1994 xantia 1.9 td and sometimes it makes a strange moaning sound as I walk away from it after a run in it, I would appreciate any ideas as to what it might be, other than that and a rattle from the front offside on anything other than a snooker table surface its runs great, its gone through 3 mot's and nothing has shown up, many thanks
- x 5671
Re: moaning noise after run
Try leaving the handbrake off and leave it in gear.
If that doesn't eliminate it I expect it will be one of the suspension struts a bit worn and vibrating as the car settles.
- x 8386
Some Xantias make that noise pretty regularly after a run and it's nothing to worry about at all. As you say Steve, just the front settling...
High pressure hydraulics can make some funny old noises..
The rattle is more than likely the drop link and they can look and feel OK but still make a racket. Cheap ones from ebay tend to be quiet for several hundred microseconds after fitting before rattling again...
It could also be the lower swivel joint but if that's the cause of the rattle the MOT man will normally have sucked a few teeth and declared his unhappiness with it.
mendedit
I used to hear the exact same thing after a shopping trip with my wife but
found I don't notice it two years on
The world is full of them and a lot are in
bill hughes
thanks mendedit but my wife wont let me go shopping with her anymore, she says she hates to see a" groan " man cry when she's spending my money
MTND
I think the funniest thing I remember was someone else's car in Lavenham which groaned when they left it and the couple walking past at the time jumped out of their skins!CitroJim wrote:Some Xantias make that noise pretty regularly after a run
Gave an opportunity to talk about Citroen's to them
Mark
1995 Xantia 1.9 TD SX owned 17 years
Alfa Romeo 916 GTV Spider 2005
Ford Focus Titanium X 2017
- x 8386
That made me
a lot Mark
Xac's does it quite regularly and it almost sounds rude...
A Xantia blowing a raspberry...
red_dwarfers
- x 58
Very funny
Mine groan sometimes, I put it down to a lack of lubrication on the front struts.
Kev
'19 C4 Cactus 130 Flair
Mandrake
- x 695
A loud groan from the front suspension shortly after exiting the car is a common quirk with Xantia's. My previous Hydractive 2 Xantia would quite often do this with the groan lasting as much as 5 seconds, and my Dad's non Hydractive Xantia also did it occasionally although far less often.
It's caused by the front anti-sink valve closing just as the height corrector is open making a downwards correction to the height.
The anti-sink valves are not designed to close during an active flow (such as the height corrector lowering the car) and it sets up a parasitic oscillation in the anti-sink valve that causes one of the pipes that runs across the firewall from the anti-sink valve to oscillate and vibrate against its mounting, a bit like a poorly supported water pipe hammering - the pipe is where the noise actually comes from.
Apparently there was a Citroen modification note that changed the mounting for the pipe to prevent its vibration from making an audible noise. (Probably just an extra rubber grommet clamp at the right place along the pipe to better support it and damp the oscillation)
Because the noise only happens if the anti-sink valve is closing at the instant the height corrector is lowering the car it usually won't happen if the accumulator sphere is in good condition - as long as the pressure at the pressure regulator is maintained well above the suspension pressure until after you have got out of the car and the car has corrected its height down then the noise won't happen.
So if your accumulator sphere is good and there is no unusual pressure loss in the hydraulic system it generally won't happen unless you sit in the car a long time before getting out.
In the case of my Hydractive 2 Xantia I had a leaky front electrovalve which drained the accumulator pressure quickly after the engine was turned off which is why it often groaned. After I replaced that electrovalve the groan went from frequent to very rare.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
- x 8386
If the Hydractive electrovalve is really leaky then it'll be much less a groaning noise and more like the noise of a flushing toilet....
Mandrake
- x 695
It's not the electrovalve that makes the noise Jim, (well, a leaking electrovalve does make a very faint hissing noise of its own that's easily missed) it just helps bring about the conditions that are needed for the groan to occur - which is a rapid loss of system pressure after the engine is turned off.
As I said, unless you sit in the car 10-15 minutes or more before getting out, the noise should not occur as there will still be plenty of system pressure to keep the anti-sink valve firmly open. If the pressure drop causes the system pressure to be marginal (near equal to suspension pressure) by the time you get out of the car and it is adjusting itself down, the groan can occur. The noise comes from a pipe running along the firewall.
If the car is non hydractive its almost certainly a flat accumulator sphere as there isn't much else that would cause a rapid loss of system pressure. If its Hydractive 2 it can still happen even with a good accumulator sphere if there is a leaky electrovalve.
Of course any fault that causes the system pressure to leak away quickly after the engine is turned off can potentially cause this groaning noise to occur.
A pressure gauge tee-d into the pressure regulator output on the OP's car I'm sure would show the system pressure dropping quickly after the engine is turned off. Thats how I diagnosed mine. I had a perfectly good accumulator sphere but the pressure was dropping in half in only about a minute due to the leaking electrovalve. When I replaced the electrovalve the rapid pressure drop disappeared, and so did the groan.
By the way my V6 has not made this groaning noise even once, but it has a good accumulator sphere and has very low leakage in the hydraulic system. I've timed well in excess of 5 minutes with the engine off before the hydractive soft mode reverts to hard mode (tested by bouncing the front suspension with engine off and a door open waiting for it to firm up) which is excellent.
Simon
1978 CX 2400
1978 CX 2400
- x 94
so it only used to do it when with the other halfbill hughes wrote:thanks mendedit but my wife wont let me go shopping with her anymore, she says she hates to see a" groan " man cry when she's spending my money
maybe the mod's can put this in the useful fix/sticky section
Regards, malcolm.
Rhothgar
- (Donor 2026)
- x 221
Mine yawns like Bagpuss!
