Keyfob Battery
Timmy69
Keyfob Battery
Unread post by Timmy69 »
Hi
I am having a little problem with my key..The problem is it opens the car by remote..from a decent distance too.But i can't lock the car with the key by remote unless i use the key in the lock manually (if that makes sense.Do you reckon i need a new battery or is it buggered ?
Thanks In Advance
Timmy
oneday
Re: Keyfob Battery
Unread post by oneday »
what car is it
306 1.4 LX MERIDIAN
Timmy69
Re: Keyfob Battery
Xantia 2.0L Hdi
x 3296
Re: Keyfob Battery
It is more likely that the 'lock' button has a failed solder joint. As the car unlocks off the fob, the main electronics are working. I would have a look at the solder joints, and (if you know what you are doing) re-solder any dodgy joints.
citroenxm
Fallen Hero
x 70
Re: Keyfob Battery
Unread post by citroenxm »
Its HIGHLY likely the switch has come away, its a common thing...
The issue is the switchs are surface mounted and have no stengthning mounting... Theres one of two chances. The switch will break off and LEAVE the soldered corners on the board, OR it will break off AND also take the printed circuit with it, which then almost renders it useless...
Remove the cuircuit board Timmy and send it to me.. Ill have a look and see if I can recover it at all for you....
The car WILL still start because the immobilser chip is in the key BLADE and not on the PLIPPER cuircuit board...
A very sad...
1994 XM 2.1 d auto
