Hi I have a dispatch on a 54 plate I've recently noticed that when I'm driving in 4th gear or up a slight hill, the van pulls back like forward and back motion! Does any1 know what this could be?
I have recently had a new high pressure diesel pump put on in December, and a new cam belt, do you think it could be this that is making the pull back motion?
Citroen dispatch 20 HDI
- x 1240
Re: Citroën dispatch 20 HDI
Sounds like fuel restriction or air ingress, did you change the fuel filter?
Dispatch54
- New User
Hi Peter
I presume the garage changed the fuel filter,would that cause this problem? I have noticed around the top of the fuel filter its damp like the top isn't screwed on tight enough!
Luke
Luke
