C5 Headlamp Adjustment
Darners
Unread post by Darners »
Planning a trip to France in the near future and as wondering if I needed to put some headlamp convertors onto my C5 (2009)
Non Xenon,
Read loads of conflicting reports, some saying that you need to get a letter from Citroen to say you dont need to use them !!!!
Any help appreciated
Citroen C5 2.0HDi Vtr + Nav 2009
If it has wheels or a skirt, you cant afford it!!
x 3565
Re: C5 Headlamp Adjustment
I put beam correctors on my standard headlamps (not retina burning projector lamps !) last year and they worked as they should, they didn't melt to a messy blob, civilisations did not crumble, empires did not fall, and everything was fine. I peeled them off afterwards and only needed a little cleaning to restore everything to standard. I believe the usual work around is to wind the lamps down using the height corrector dial by the steering wheel. None of the above applies to 'projector' lamps !
qprdude
x 14
Unread post by qprdude »
bobins wrote:I put beam correctors on my standard headlamps (not retina burning projector lamps !) last year and they worked as they should, they didn't melt to a messy blob, civilisations did not crumble, empires did not fall, and everything was fine. I peeled them off afterwards and only needed a little cleaning to restore everything to standard. I believe the usual work around is to wind the lamps down using the height corrector dial by the steering wheel. None of the above applies to 'projector' lamps !
MMMmm, I too am considering a visit to the Tours area this year, but the Exclusive does not have manual adjusters.
Rick.
2013 Citroen DS 5 D/Sport
x 5672
Cars with hydraulic suspension won't have manual adjusters as they are just to compensate for variations in loading and the hydromagical suspension does that all on its own.
qprdude
x 14
Yes, but what to do when driving to France? Brother-in-law uses stickers on the lenses.
Rick.
old'uns
x 127
Unread post by old'uns »
i'll be using 'old skool' tech....Black tape or some bits of vinyl i've got lying around...up against a wall and sticking where i 'think' it won't dazzle, at least it looks like you've made an effort :)
at least with the old C5 you can use the fogs with sidelights, not much worse than blanking the dipped ones and it still looked like dipped were on
