diesel leak
bill hughes
diesel leak
Unread post by bill hughes »
1994 xantia 1.9 td I intend replacing or repairing the fuel filter body as I have a leak from the water drain plug can I use jubilee clips on the hoses instead of the originals, or any other suggestions many thanks
x 94
Re: diesel leak
Unread post by citronut »
hi and welcome
you can use jubilee clips but the original ones arent that bad when you have done a few,
use either a pair of side cutters or carpenters pincers to release and re/fit them as they are just snapped together
were are you located
Regards, malcolm.
bill hughes
Re: diesel leak
many thanks Malcom I thought at first glance they were crimped on.the filter body is leaking from the recess where the white water drain plug is, but not from the plug itself, I am based in France
Bill
evilally
x 3
Re: diesel leak
Unread post by evilally »
If you can't re-use the originals, you should be able to purchase proper fuel line clips from a local motor factors for not much money. They are much like a jubilee clip except the apply a more even pressure, if not they are readily available on ebay. I also find a quick heat with a hot air gun or maybe a hair dryer makes old fuel lines much easier to remove.
'97 406 1.9TD, 314k.
bill hughes
Re: diesel leak
To Malcolm and Evilally many thanks for your advice but I have managed to seal it insitue, if it works ok I will post the method, but dont want to count my chickens
Bill
