fuel guage faulty
martyn48
fuel guage faulty
Unread post by martyn48 »
hi my 306 cab has developed a fuel gauge fault.the low fuel warning light is always on even if i put £20 of fuel in.ive fitted different clocks but the fault is still there i have taken the multi plug of the sender /fuel pump and the light is still on surely that cannot be right if there is no power getting to the unit any :idea: folks
DickieG
Monaco's youngest playboy
x 33
Re: fuel guage faulty
Unread post by DickieG »
Unless I'm mistaken the gauge will read nil and the light stay illuminated when the multiplug is disconnected, from your description I suggest a faulty sender unit in the tank might be the cause.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
martyn48
mmm good point mate i wasnt thinking straight #-o
evilally
x 3
Unread post by evilally »
Take the sender out, put a multi-meter on the plug and move the float up and down. You should see the resistance varying as you move the float. If not, then faulty sender.
'97 406 1.9TD, 314k.
