Hi
What is the function of the Hydraulic Circuit Safety Valve ?
Zohar
Xantia- Hydraulic Circuit Safety Valve
lancia58
- x 8
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
- x 94
Re: Xantia- Hydraulic Circuit Safety Valve
the function of the safety valve is to give the brake circuit priority over the suspension circuit,
the hydraulic pressure feeds straight through the safety valve with no restriction at all, and the pressure has to build up enough to open the valve before feeding the suspension,
it also has the main pressure switch that puts the STOP light out on reaching working pressure
were are you located Zohar
Regards, malcolm.
