I need to change the battery on my HDI soon. As it's not possible to de activate the alarm without a lexia, what do you do?
Or is ear ache inevitable?
Any precautions needed?(I don't mean earplugs)
Is it possible to change the battery without interrupting the power supply with a third battery?
Kind regards
Paul
Changing battery on HDI
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
Re: Changing battery on HDI
just remove battery alarm will not sound. when refitting batery there is a sequence to follow you will find it in the hint and tips forum
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
- DickieG
- Monaco's youngest playboy
- x 38
The easiest way is to use a third/slave battery connected to either the cigarette lighter or the battery cables as this maintains the radio code, re the alarm when you re-connect the alarm will go off, simply lock and unlock the car quickly with the remote, job done.
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
dont know why i got it into my head this was a c5 sorry
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
I like the idea of using the lighter socket, re coding everything is a right pain. Is there some sort of gizmo availabl;e Richard?
kind regards
Paul
kind regards
Paul
Why all this unnecessary complication ? We're talking about a Xantia here.DickieG wrote:The easiest way is to use a third/slave battery connected to either the cigarette lighter or the battery cables as this maintains the radio code, re the alarm when you re-connect the alarm will go off, simply lock and unlock the car quickly with the remote, job done.
The alarm will only go off if the car is locked and the alarm if armed at the time the battery is disconnected...if the car is unlocked then by definition the alarm will not be armed and will NOT go off when the battery is disconnected.
Nor will the alarm go off when the battery is reconnected. Why would it ?
To the OP - just make sure you have your radio code and/or immobiliser code if applicable before disconnecting the battery. You have nothing to fear disconnecting the battery on a Xantia.
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
- New User
- x 39
I was wary because my previous two Xantia's alarms would sound when the battery was disconnected and the siren had not been de activated with the key. It's not possible to do this with a Hdi Exclusive.
Cheers
Paul
Cheers
Paul
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Series TWO Xantias dont have the silly "Need to reset the Alarm" procedure like Series ONE Xantias!
Simply swap batterys... and drive away! Oh, and re enter your radio code! Thats it.. Theres NO Alarm reset procedure needed on S2 Xantias...
C5's are even easyer! When you refit a battery just wait 5 mins and drive away! No need to enter ANY codes what so ever, not even a radio code....
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Thanks Citroën XM
Cheers
Paul
Cheers
Paul
